EGR blockoff plates
OK so I've run into a roadblock with my stalling issue, and I'm going to start changing things to pinpoint my problem. My CEL is illuminated because of the EGR system, and instead of replacing it for $120, I think I might try the blockoff plates for $50.
I just wan't to know a few things first. Is it just a matter of putting the plates in their places, or do you have to remove the entire system like the solonoid and temp sensor? How much fuel milage is lost? And has this thrown a CEL for anyone who has used them? I hear it only happens in Calli but I'm not sure if that's true or not. |
Re: EGR blockoff plates
Do you even know what the good side of the EGR system Does? It does not look like it opcorn <First one to use this smile!) . I dont think you want to heat up your block anymore and get some knock. And yes i read about it and did some research linebckr
A) I never recommend changing to anything new when trying to pinpoint a problem. Why add something to the equation. I can't really see how the EGR system would be causing your stalling. I mean even if the valve was stuck open all the time, it normally is open at idle anyway (I believe...it should only close at full throttle), so that wouldn't make a difference. So unless you have some huge plenum leak in hte EGR pipe or something (which would be easy to find via pressure test)
Something like this: ![]() ...I don't see it being the problem. Speaking of which, have you pressure tested??? B) Are you sure that is the only code your ECU is showing? Perhaps scanning the codes will lead you to your problem. C) EGR plates should throw a CEL on OBDII cars, and I believe hybrid ecus as well, so basically you are only good on 91-93s, without putting in some type of resistor to fool the ECU. Now I say SHOULD, because for some reason, some people have gotten away without ever getting an EGR code, however, typically you should expect one to come on. Even then, you will most likely fail any type of visual emissions inspection...and probably fail an exhaust sniffer. D) You can just install the plates, or you can delete teh entire system...it's up to you. But again, if you don't have a 91-93, you may get additional CELs if you remove the EGR solenoid. E) not really sure how much gas mileage suffers. It would only affect your gas mileage at partial throttle and low load, allowing more clean air into the combustion chambers, so your gas mileage may suffer a tad under those conditions...but again, I don't know how much. F) if you insist on doing this, don't spend $50 for plates. Just cut some aluminum or something in the shape of the EGR gaskets, but without the hole in the middle and just use that. Save yourself $49.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Yea that's true. The block gets pretty damn hot. I'm pretty tight on cash right now. What's the lowest price I can get for the valve and probably a new hose as well. Or is there a replacement kit out there?
No I haven't pressure tested, and I have new gaskets on the way as well for the TB, upper/lower plenum/ and both valve covers. I think the first thing I should do is get the cheap stuff out of the way and see if that doesn't work, make sure I don't have any vacuum leaks, then move to the more expensive stuff like sensors and what not. |
Decent thread on EGR affects on gas mileage and knock.
a) exhaust gas is 1000+ degrees...that's a hell of alot hotter than intake temps. b) egr = carbon deposits. Carbon deposits = hot spots. hot spots = knock. The EGR system was added to reduce emissions, not aid gas consumption or reduce knock. I've researched this alot too. And while EGR deletes will always be debated...just as much as underdrive pulleys, I personally lean towards deleting it.
Well I will say this. Whatever my problem is, it's eating my gas. Weather it's because I've restarted a million times because of constant stalling or peeling out in frustration. Before this week (when my problem began) I was getting 28MPG. (usually that's about 250 miles with half a tank left) This week I've driven about 230 miles and I'm almost at quarter tank. So whatever my problem is, I'm eating my gas up.
plugs and wires can help fuel economy? have you changed those? do you know when they were last changed? pull the front 3 plugs and inspect their condition.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
yea that's on my list of things to do. But for 2 months my economy was 28MPG consistently. Up until one week ago it dropped drastically. Plugs usually go bad over time, not in 7 days.
