Old 11-13-2006, 01:07 PM
dcc205 dcc205 is offline
Need electrical help
I've been having an issue for the last couple days with my tail lights staying on after my 99 has been shut off. I'm also getting the door ajar light on and my gas gauge jumps for the current level to empty constantly. This has all been occuring for the last 4-5 days. I'm also having trouble with the rear fan. This moring, after the van sitting all weekend, the battery was totally drained.
Anybody have any clues as to what is occuring? I've been pulling two fuses to get the tail lights to shut off.
Thanks!
Old 11-13-2006, 07:18 PM
wiswind wiswind is offline
Re: Need electrical help
I have seen posts about a GEM module that can fail......causing tail light problems.
I have no experience with that.
I would check the Brake On Off (BOO) switch that is up under the dash....mounted to the brake pedal shaft.
If it is NOT connected, the tail lights should be OFF.
I have pictures of the BOO switch in my pictures.
That would be cheaper and easier than the GEM (General Electronics Module)
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-14-2006, 08:03 AM
Thanks! I'll check that tonight.
Do you know where the Hazard Flasher Unit is located on the 99? The manual I have says it should be by the fuses in the drivers compartment, but I can't find it there.
