What do I need on the D30 if I put 4.88 gearing on the D35?
What gear ratio do I need on the D30 up front if I put 4.88 gearing on the D35? Also, is this gear ratio too extreme for my axles (with 35s)? ...I do go a little heavy on the skinny pedal when I'm late for work (5 days a week), but I don't rock crawl... Only hill climbs and mudding. Thanks for any and all input... but no, I will not put smaller tires up front.
'98 Eclipse RS ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now). SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere. |
Re: What do I need on the D30 if I put 4.88 gearing on the D35?
well now, I would think you would have to have the same gear ratio on the front as you have on the back. Have you ever worked on gears before? I think you would just change the ring and pinion gears, buy the kit, it comes with a zillion spacers for setting it up. I have 3.07 gears right now, sucks on take off but good gas milage, at 60 mph it revs about 1450 rpm.
different axles does not really matter. lots of vehicles come stock with different front and back axles in them. but you have to have the same gear ratio in both thats what matters.
so if you put 4.88 in the back you have to do it in the front.
89 jeep wrangler with a 360 amc v8 40 over msd ignition system from box to wires edelbrock performer intake, cam holly fuel inj k&n air filter tubro 400 trany with shift kit dana 44 axles 4.56 gears all 4 wheel power disc brakes 6 1/2 inchs of suspension lift rci racing seats simpson 5 point harness griffin aluminum radiator REAL JEEPS ARE BUILT NOT BOUGHT LIFT IT --- FAT CHICKS CAN'T JUMP |
the onyl way you can have a differant gear setup in the front and rear is if you NEVER engauge 4-wheel drive. things will go flying and you will end up in jeep hell if you engauge 4x4 with differant gears in the front and rear.
so only change the rear all you want, just dont put it in 4x4. and if you order 4.88's for the the front make sure you get revearse rotation too. 4wheelparts.com has a good deal on gear set ups. front and rear with install kits for somewhere around 400$. you'd have to check to make sure. as far as 4.88 with 35's. that is as big a tire as i would go. 2.5, 4.0? whats under the hood?. if u have the 2.5 4.88 with 35 is the limit. if you have the 4.0 you should be ok. but if you want to go any bigger you might want to look at 5.13 gears. esspecially if you have the 2.5. but if you go 5.13 i think you will need a new carrier. i think that the housing will still work. but that is another ball game |
Well... I need to think a little more before I start a thread! Thanks for all the responses. And, Branden, I didn't know you had to worry about reverse rotation. I will definately check out 4wheelparts.
Btw. I do have the 4.0. I am putting cams for 10% more tq (with everything that takes), headers, magnaflow cat, and borla muffler. And eventually I want to add a centrifugal supercharger, bore and stroke to 5.0L and add some nitrous after that (on a throttle position switch)... plans for plenty of hp. I just haven't found the cash for the D60 and various driveline parts I'd need to handle the power. Feel free to PM with and questions or suggestions about this.
look at it this way....look at your rear axle...then the front....the front one is the oppisite of the rear.....hence revearse rotation...
your gonna put notrous on a jeep????? |
yeah the reverse rotation does make sense. And yes, nitrous. lol I've done a couple hill climbs where the Jeep just couldn't push anymore. Gearing is one answer... but it's also my daily driver, so I need to keep the gas mileage at a decent level while cruising at 70mph. Nitrous is good for some high end power to get going, and then the supercharger and cams will help with some low end torque. So when I win the lotto I'll be able to build my Jeep right. lol
Same ratios in all axles, unless you're driving one of these:
![]() And I think with nitrous you're going to blow up the Dana 30 in the front, and probably the 35 in the back as well.
Ours: 2020 Jeep Wrangler 2.0, 53k 2013 Toyota FJ Cruiser, 84k Kids: 2005 Honda CRV, 228k |
The lowest gears you can get for the TJ D30 and D35 is 4.88s. Some axles use 4.88s and some use 4.89s. Thats ok, they are basically the same and work fine together. |
ok so no reverse rotation... time to research. lol And I will be getting a D60 or D44 for the rear and D44 for the front... And nitrous is way down the list of things to waste my money on. There are so many other things to do... But if I have it on my Jeep, there will be a good, practical reason for it. Thanks again for all the input.
how do you figure there not revearse rotation? back it up please
Ray's know what he's talking about in the past... helped out a lot. Either way, I will be researching and I'll update with an answer... But that might be a couple months away.
If you need proof im sure you can do some research and compare part #s. EDIT: I'll get you started. Actuually heres a couple write ups that Kuhn may be interested in. http://www.4x4wire.com/jeep/tech/axle/tjhpd30/ http://homepage.mac.com/rv6a/hpd30.html and heres the scoop on Jeep D30s.http://www.jeeptech.com/axle/d30.html As a side note, the Rubicon has a D44 in front, it is also standard rotation. |
Ray comes through as usual!
lol cheers
Hey Ray,
Thanks for the links. I am looking into changing out my 3:77 (OEM) to 4:88's I found that purchasing a complete 4:88 axle from a friend, that is moving up to D44's, is cheaper then having the gears installed at 4wheelparts.
www.jeepforum.com; www.socalultimate4x4.com 1998 Wrangler (replaced my 88 XJ) 21' Mini Winnie (replaced my Pace Arrow) |
