Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-13-2006, 10:49 AM
panther79 panther79 is offline
Crown victoria........ go digital?????????
I have a 96 vic with an anologue dash, and a 96 marquis with a digital dash. is it possible to convert my vic to digital? how involved is this job?
Old 11-13-2006, 08:11 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Crown victoria........ go digital?????????
This has been done, and I *think* it is "plug-n-play" for a '96.
Check on www.crownvic.net for additional information (accessories and detailing).
Old 11-13-2006, 08:55 PM
reekor reekor is offline
You'll need a different wiring harness for the cluster, along with a engine temperature sensor and harness and a oil pressure sensor. If you want the outside temperature to work you will need to mount the temperature sensor on the rad support, I'm not sure if the if analog cluster cars have the outside temperature sensor plug in place or not, you may or may not need a harness for that. Also not sure on what is needed if anything to get the curse control on/off light to trigger.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
