Old 11-13-2006, 09:21 AM
sport01 sport01 is offline
check engine light?
I have a 97 voyager with a 3.0 v6. The CIL stays on all the time. When we read the codes it says missing on multiple cylinders so we put new plugs,wires,cap, and rotor. Then we cleared the codes and the next time we drove it the light came back on with the same code missing on multiple cylinders. Any ideas? Thanks.
Old 11-13-2006, 12:09 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: check engine light?
http://www.autozone.com/servlet/UiBr...3d801a3ba1.jsp
Also check the primary and secondary coil resistance. Primary should be less than 1 ohm secondary should be 10-15 kohms.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-14-2006, 07:19 PM
Thanks, I will check the coil next.
Old 11-21-2006, 07:28 PM
Checked the coil and found the primary was 0 the secondary was 13. Does this mean that I need a new coil? Thanks!
Old 11-21-2006, 08:22 PM
wafrederick wafrederick is offline
Banned
It could be fuel injectors too and a bad fuel injector will cause a missfire.Try pouring some Lucas fuel injector cleaner first in the gas tank.Lucas is the best fuel injector cleaner on the market.Stay away from STP and those cheap injector cleaners,they contain solvents and Lucas does not.Lucas is sold at most auto parts stores.
