Old 11-13-2006, 08:43 AM
QueTipp QueTipp is offline
95 s10, new MFI = Hydrolock
Hey everyone, this is my first post here. I need some help with a 95 chevy s10. It is a Vortec engine and I replaced the MFI fuel injector and the 2 fuel lines that go to that.
Everything went pretty smoothly while I was replacing the Injector, but when I tried to start the engine, it turned a couple of times and then the engine would no longer turn. I have diagnosed that one of the cylinders is filling up rapidly with fuel and is causing hydrolock.
My question is, why do you think that the one cylinder is filling up so fast with fuel? It's a brand new fuel injector, so the only thing I can think is that I put the poppet in wrong or maybe you guys can offer a suggestion?
Thanks
Old 11-13-2006, 08:56 AM
Re: 95 s10, new MFI = Hydrolock
Also, I've seen you guys refer to this injector as a CPI. Didn't want to cause any confusion.
Old 11-13-2006, 12:41 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 2nd Blazer Problem 93 4.3V
Originally Posted by QueTipp
Guys, I had to replace my CPI as well. I did this over the weekend. I replaced the nut kit also. I am having a problem with one of the cylinders getting flooded out with fuel now. It causes hydrolock. I had to remove the spark plugs to push the gas out of the cylinder. Does anyone have a suggestion as to why the cylinder would fill rapidly with gas with a brand new CPI unit?
You didn't put the o-rings on the nut kit where it goes into the CPI injector.
Remove the plenum cover and see what you missed.
That or you have no spark.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-13-2006, 08:11 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
When you get through, have somebody just turn the keyswitch ON...(don't try to start the motor) while you observe the CPI and fuel lines to check for a leak before you put things back together.
Check that the injector to the flooding cylinder is still on it's injector line.
After flooding that hard, you'll need to change the oil again before starting the engine.
Pro's/Anybody/Everybody...can you check the CPI injectors for squirt while the plenum is opened?
Old 11-14-2006, 09:11 AM
The o-rings were on the lines already when they came in the package. I took the fuel lines out of the CPI and put them back in. Then I engaged the fuel pump and there was no more leaking. I turned the engine over without the plugs installed and there was no more fuel spurting out. I hope this fixed my problem. I am going to finish up the rest of the job tonight with new plugs, new oil and filter. Thanks for the help.
Old 11-14-2006, 01:22 PM
anyone know where i can buy new bolts for the plenum?
Old 11-14-2006, 04:59 PM
AF - Advisor
Your local auto recycling center/boneyard should be full of them.
Old 11-15-2006, 09:24 AM
I got it up and running again. I guess I didn't secure the fuel inlet line tight enough into the CPI unit. Runs like a champ now. I also went with a suggestion in another thread and that was to drain the old oil and run it with new oil (for 10 minutes or so) and then drain again.
