Old 11-12-2006, 07:20 PM
Ron21 Ron21 is offline
1999 Escort ZX2 code 301
I have a 99 Escort ZX2 with the 2.0L DOHC. Every so often the engine will run rough and the check engine light come on ad displays code 301 which is cylinder 1 misfire detected. I have changed the plugs (NGK plantium laser installed)and wires and still does it. I have tried high test fuel which seems to have helped but still does it every so often maybe every 400km for about 5 minutes then tuns fine again).
Any ideas on what else may be causing this would be appreciated.
Thanks in advance
Old 11-12-2006, 08:56 PM
youasked4help youasked4help is offline
Re: 1999 Escort ZX2 code 301
Thanks in advance
Im not going to stand behind this obd older model computer codes. but it use to be: 301 missfire on cylinder 1
Learn Steps to painting a car www.you-asked-4-help.com
