Old 11-12-2006, 02:43 PM
drunken monkey's Avatar
Razor Sharp Twit
90% complete Ferrari 612 Scaglietti
not the one I mentioned in another thread but i've had this one going for ages and having had an accident to the paint which I couldn;t fix properly really put me off.
looking at how many other kits I've got to do though spurred me to get it finished as soon as possible and now, apart from a few decals and trim details, it's 90% (ish) complete.
one thing I wanted to do with this kit was to see if i could "fix" the stupid revell wheel system.
the result
front:
rear:
this was my second metallic/clear job ever and it's not perfect having been rubbed through on a few areas after failing the resist more polishing after painting trims and glassworks and stuff.
Engine is out of box but I made a few minor corrections and the next one will have a few details that are missing added....
AF's Guidelines
Read them.
Old 11-12-2006, 03:24 PM
subcool subcool is offline
Re: 90% complete Ferrari 612 Scaglietti
The paint looks excellent in the photos. Great job!
Current Project: VW MK1 Golf Custom
Old 11-12-2006, 08:22 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
A 90% Ferrari- man, I know what that's like.
The color looks great on it. Good shine on the bonnet. Rosso Rubino?
PHOTOBUCKET SUCKS
Old 11-13-2006, 03:08 AM
auw12's Avatar
auw12 auw12 is offline
love the color choice,great work so far.
Old 11-15-2006, 09:08 PM
Razor Sharp Twit
nope.
don't have an airbrush so everything I do is handpainted and spray can.
body is three coats (one light "danger zone" coat then two all over wet coats) of tamiya mica red (my new favourite red) over a gold base coat.
this was actually started about a year ago as a side by side test of metallic red and mica red over a gold base.
the metallic red car is just a body right now.... i.e 15-20% complete....
edit:
an old pic that i've shown before but of these ones, only the lotus, dino and scag and bmw are nearly finished.
the ZR-1 of the other thread I actually started after these and I managed to get more done to it than these.
AF's Guidelines
Read them.
Old 11-15-2006, 09:31 PM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Question : did u drill the holes to fit tamiya rims ?
Old 11-15-2006, 09:42 PM
Razor Sharp Twit
nope.
i rescured some polycaps from my spares box and drilled out a hole for them in the wheel hub.
then I cemented the brake disk to the hub.
the strange yellow you see is my own plastic weld+sprue mix that I use for a solid filling material because I couldn't get the hole perfectly in the centre the first time around.
the wheels were simple, cut out the rear set of spokes and glue the two halves together. you just then locate the centre of the wheel and drill a little hole to receive a length of plastic rod.
i've just started prepping another one of these so i'll be sorting out another set of wheels+hubs.
I'll get pics of that process when I get to it.
AF's Guidelines
Read them.
Old 11-15-2006, 10:20 PM
Gamerxz's Avatar
do u have a solution on how to convert the car so it will kit with tamiya or fujimi rims?
Old 11-15-2006, 10:35 PM
Razor Sharp Twit
tamiya rims will be the same as above.
fujimi will be a bit more difficult - in this case, it makes more sense to me to convert the "female" fujimi to tamiya style "male" type fitting and just do the same as I did.
that means you'd still need a set of poly-caps and a suitable bit of plastic/metal rod that will fit the poly-cap.
AF's Guidelines
Read them.
Old 11-15-2006, 10:52 PM
Razor Sharp Twit
update:
modified wheel: it's not the tidiest wheel in the world but from the outside it does the job.
and some of the interior.
this was just box stock and hand painted.
there are errors in details that I know for next time and I still need to fabricate a gearshift panel cos mine went down the drain after stripping that chrome.
DM.
AF's Guidelines
Read them.
Old 11-16-2006, 01:15 AM
auw12's Avatar
OH MY GOD!!!!!!you have a 250GTO and a SWB those are what i badly wanted!!!!!so envy you man!!!that interior is just amazing result for hand painting!keep it up!!
Old 11-16-2006, 07:44 PM
eph2 eph2 is offline
Send a message via MSN to eph2
Wonderfull work and paint in every models!
Old 11-16-2006, 09:24 PM
Gamerxz's Avatar
Originally Posted by drunken monkey
update:
DM.
Thanks for the info... how many mm was the rod u used?
Old 11-17-2006, 07:05 PM
NissanSkylineGTR98's Avatar
Looks great, that colour is awesome!
Steve
Old 11-18-2006, 03:48 PM
milarazor's Avatar
milarazor milarazor is offline
Thumbs up Re: 90% complete Ferrari 612 Scaglietti
yees, its cool
