Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-12-2006, 12:50 AM
marc's95esi marc's95esi is offline
I need help with my Talon!
I have a 95' Eagle Talon ESI with a 2.0l non-turbo motor in it.My timing belt started to bash against the cover so I shut the car off immediately.The car still ran though. I bought the kit and started to replace the belts and tensioners and i checked out the camshafts. The front camshaft will turn but the back camshaft will only turn one time then stop. I assumed it was a bad valve but i'm not sure yet. Is there anything little that it may be that i just didn't notice? Any help or advice would be greatly appreciated. Thanks.
Old 11-12-2006, 12:58 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: I need help with my Talon!
Welcome aboard. Please read the rules and post in the correct subforums.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-12-2006, 01:11 AM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
The camshafts shouldn't move freely if your head is still on your car. They should be very hard to turn and they tend to find a "groove" where they sit in and make it very hard to turn when turning the camgears.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-12-2006, 01:50 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
That camshaft won't turn anymore because one of the valves is hitting one of the pistons. Do you have a shop manual like Chiltons? If not, I would recommend getting one before you jump into this timing belt operation, you will either fix the car, or break it worse if you fuck up. There is no in-between when it comes to timing belts. Also how many miles does the car have? Might as well put a new waterpump while your at it (involves removing the timing belt if it ever goes out)
95 Talon TSI AWD
97 Eclipse GST
Old 11-12-2006, 01:59 AM
I'm not personally doing the work but yes we do have a Chiltons manual also. The car has 190k on it. We are changing the water pump also. Do you think that there is a bad valve or what? We were going to take the head off tomorrow and take it somewhere but if this is normal then that would be great. Thanks for the help.
Old 11-12-2006, 03:16 PM
Do a compression test, it'll tell you if you bent a valve or not. If the belt didn't actually snap and let go, you should be fine. Also at 190k, you should probably go with a new tensioner and idler pulley.
95 Talon TSI AWD
97 Eclipse GST
Old 11-12-2006, 09:14 PM
Well thanks for all the help. The belt didnt actually snap and i am changing everything. The valves did go bad. I will let you know how many in a few days after the machine shop gets back to me. Thanks again.
