Old 11-11-2006, 11:46 PM
amichals amichals is offline
Amplifier question
how would i get my alpine MRD M1005 amp to do the 1000W x 1 (1%THD) load? These are the specs on it and i was confused about how it pushes out 700 rms at 2 ohms but also can push out 1000 rms at 2 ohms.
RMS Power (at 12V,20Hz-200Hz)
Per channel into 2 ohms : 700W x 1
Per channel into 4 ohms : 500W x 1
RMS Power (at 14.4V,20Hz-200Hz)
Per channel into 2 ohms : 1000W x 1 (1% THD)
Old 11-12-2006, 11:24 AM
Re: Amplifier question
im trying to get 2 12 inch type r's with dual 2 ohm voice coil powered to there full potential in RMS
Old 11-12-2006, 03:53 PM
PlayStation3 PlayStation3 is offline
the 700 is when the car is not running and is being powered off the battery and the 1000 is when the car is on and is being powered by the alternator
Old 11-12-2006, 09:36 PM
o ok...thank you
Old 11-13-2006, 06:14 AM
no problem
Old 11-13-2006, 08:17 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
to expand on that .... 700 watts is at a bettery voltage of 12 volts, the 1000 watts is at an alternator charging voltage of 14.4 volts. So you're amp is getting like 20% higher voltage, and it's more efficient at making power at the higher input voltages - it's called a loosely regulated power supply.
