1986 running bad
We have a 1986 D21 pickup with the 2.4 L (Z24) engine. The engine is having trouble starting in the morning and runs very sluggish until the engine warms up. Once warm the problem seems to go away.
Tried to change the ECM but the truck would not start at all. Changed it back and it will start but still runs sluggish. Tried to check for codes it will not blink 4 times but does give codes. Codes are 13, 23, 24. Any ideas? |
Re: 1986 running bad
Code 11 engine coolant temp (ECT) sensor
Code 23 throttle valve switch Code 24 Transmission switch
'99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '98 Pontiac Grand Prix GT, 3.8 '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
change the coolant sensor and forget about the other 2 codes..
they go away when you shift and push the gas pedal .. |
Why would the coolant sensor have anything to do with why the truck is running like $hit?
I mean the truck sounds like it is not getting enough gas wanting to stall out. |
the engine is run by a computer .
the computer is getting no signal from that sensor. when you first start the truck it is cold. the computer does not reads this so it does not regulate the fuel for a cold engine . when it does warm up it is fine. change the part . |
You just give me the codes and I put them up. We nned a little more info here like when was the last tune up, fuel filter changed, things like that.
no more info is needed.
he has the codes . they have been posted. |
The sensor was the problem. Thanks guys again for your help.
