Old 11-11-2006, 07:51 PM
kidwild kidwild is offline
89 Grand Prix no headlights
I have a 89 Grand Prix that the headlights and tail lights are not working. The turn signals and brake lights still work. I have checked the fuses and all of them are still good. Any ideas where to look for this problem?
Old 11-12-2006, 07:02 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 89 Grand Prix no headlights
do any other runnung lights come on like the front running lights or corner lights? If not, then the headlight switch is probably bad.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-13-2006, 01:08 AM
jonsonton's Avatar
jonsonton jonsonton is offline
Do you know if the circuit runs off of one ground?
Old 11-18-2006, 11:28 AM
None of the running lights come on. The turn signals work but the flashers do not.
If it is the headlight switch which switch is it and is it had to replace?
Thank you
Old 11-18-2006, 11:40 AM
richtazz's Avatar
On an 89 Grand Prix, its on the dash to the left of the instrument cluster.
Old 10-21-2007, 09:16 PM
I started looking at the problem again, the car has been stored, and i have found out it is not getting power at the fuse panel. that is as far as i've been able to track it. any ideas what the next step should be to try and locate the problem?
Old 10-22-2007, 02:26 PM
richtazz's Avatar
Wow, it's been a while and you still haven't figured it out huh? Normally we'd close a thread this old, but since you're the OP, we'll let it go.
I'd start by loosening the underhood fuse/relay center on the passenger side and see if the underside is all green and corroded. It's a fairly common issue on these cars, especially if you live where they use salt on the roads in winter.
Are there any other dead circuits (dash lights, door chime, radio, etc...) ?
