Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 09-12-2002, 11:56 PM
chetp chetp is offline
Unhappy 83 944 runs rough
I own a 1983 944 and it was running rough. Almost like it was missing or had a fuel problem. I replaced the fuel injectors, fuel regulator, fuel filter, new plugs, new wires. Still runs rough, like its missing or running rich. Low idle. Any suggestions what it could be would be appreciated.
Old 09-26-2002, 05:13 AM
Michael Adkins Michael Adkins is offline
When you say low RPM's do you mean at idle, that low? Two common things are the motor mounts which are common to get worn. When these are bad the there will be a lot of vibration at low rpm and go away when you rev it. The other is a bad balance shaft belt.
