Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-11-2006, 04:33 PM
jtjohnston jtjohnston is offline
Trailer Wiring Harness location
I can create my own Trailer Wiring Harness, but where exactly do I find the harness plug for a factory installation of a 2004 venture?
I have found a plug with 7 (I think) wires connected to it located in the rear, driver's side column behind the rear tail light. I see green, yellow, brown wires (enough for my 4 pin installation).
But when I turn on the signal lights etc. and run a test light, I get nothing. Does the key have to be on?
Anyone have a diagram where to find it?
Old 11-12-2006, 01:08 AM
GregA's Avatar
GregA GregA is offline
Re: Trailer Wiring Harness location
Welcome to the forum!
I have a diagram for a trailer harness from a 2001 at the link below, so it should be pretty close. It looks like most of the wires are driven only when the key is ON (like turn signals & such).
Trailer Harness
Hope this helps.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 11-14-2006, 04:20 PM
Fixed: Homemade Trailer Wiring Harness for a 2004 Chevrolet Venture
Actually, a few days later, I have found my own answer.
The harness clip I found on the rear pillar was the right one.
Yellow - left signal
green - right signal
white - gound
brown - tail lights
It would appear that my test light was not working.
To save money buying the very expensive harness, or even a used harness piece, I made a very nice homemade connection to fit in the female clip.
All I did was take my four pin wire,
strip off a centimetre of each of the four wires,
twist the copper wire until it was stiff,
apply solder to the bare tips, (when cold each end becomes stiff),
nip off each end just long enough to fit (push) into the existing female harness.
The colour-codes match up.
I should use hot glue or electric tape to seal it off, but I will keep the van for a year or so; therefore, a professional job is not necessary. If the van was new, I would go buy a male clip to fit into the exisiting female harness. All the same, my homemade fix is very safe and cheaper. I essentially created my own male tips and inserted them into the existing harness.
The main thing is that the female harness connector existing in the rear driver's side column (of rear tailights) works. My tester light did not. Keys do not need to be on. And I did not have to hack up the wires and solder into the existing harness.
All you have to do is match up the existing wires, which match standard colour-codes:
white - gound
brown - tail lights
Old 11-17-2006, 12:08 PM
Problem Again: Trailer Wiring Harness location
Ok, the white is for the stop lamps. But how do i wire the white wire in without shorting the yellow & green at the same time?
