Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-11-2006, 02:39 PM
Brucifer Brucifer is offline
Throttle response problem- need help!
I am having idling problems while driving in stop-n-go traffic. If I barely accelerate and let go to brake my rpm drops well below normal rpm levels-almost like it wants to die. Also driving at higher speeds if I accelerate all the way I hear alot of clanking noise. This usually happens in colder weather. I am thinking this is an oxygen sensor related problem or fuel problem. I am looking to buy a code reader to see if it could guide me in the right direction. Is there a good one that you suggest I pick up? Any advice would help!!
Old 11-12-2006, 03:47 AM
ohiodave ohiodave is offline
Re: Throttle response problem- need help!
EBay is loaded with readers. I picked one up for about $40 or $50 bucks awhile back. They are pretty much all the same as long as you get one that is OBDII compatable.
Old 11-13-2006, 01:20 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Unless your engine is throwing a code (aka, your check engine light is on) a code reader wont tell you anything. As for the stop and go traffic low idle thing, it could just be that your aux fans are running for your radiator, which can cause a low idle, same goes for if you are running your AC on a hot day. If it were an MAS sensor problem you should have tripped an engine light.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-13-2006, 01:25 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Clanking? Like pinging? Intake plenum pan gasket is likely shot.
I bet your idle air control sensor is filthy.
My Mopars
Old 11-15-2006, 12:42 AM
Simioh's Avatar
Simioh Simioh is offline
Send a message via AIM to Simioh Send a message via MSN to Simioh
code reader, i would recommend u get the superchips flashpaq. it is kinda expensive, i just found one in perfect conditions for 325 shipped. they not only read truck codes, but they tune ur truck. it is amazing, shifting is so mufh stronger and firmer. and u get extra hp and tq. plus it has a data adquisition feature which will let u log ur 1/4 mile times, 1/8 mile, 0-40 0-60, etc etc and all that good stuff
2004 QC SB 2WD Hemi Ram
MODS
Performance-Airraid TB spacer
Volant CAI
Flowmaster 70 series di/do 2.25
XPipe
Superchips
JetStream scoop
PowerWire
Looks-Tinted Windows
Billet door pins,headrest spacers,door reflector inserts (HEMI)
Shorty antena
Spray on bedliner
Leather interior
Mopar chrome fuel door
LoRider bed cover
Projector headlights
Projector foglights
Smoked LED taillights
Blue LED map,dome,and licence plate bulbs
SRT-10 wheels
