Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 11-11-2006, 11:16 AM
dmfnded dmfnded is offline
327 in '82 Elky
i've got a 1964 327 out of a Impala of same year-will it fit in my '82?it currently has the 229 V6 in it with 200 tranny.what swaps or mods would i have to do and who makes headers for this motor/car combo? what do i do with my ECU since it wouldn't be needed?
thanks for ANY and ALL help guys.
Old 11-11-2006, 05:01 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 327 in '82 Elky
If it's an original year 1964 327, with heads the same, it will require the use of old brackets for accessory mounting as the SB up to the late '68 model year didn't have the bolt holes on the heads for accessory mounting. It will work, but you will need to replace the trans with a beefier unit.
1978-up A/G body headers will fit.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-12-2006, 07:37 AM
Re: 327 in '82 Elky
so,does anyone make the bracket that would do the changeover for the accessories?i'm sure i could fab what i need,but sometimes i'd just rather take the easy way out and spend my time on something a little more complicated.time is precious nowadays.
Old 11-23-2006, 06:39 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: 327 in '82 Elky
Just tie the wires back so they dont get stuck in your throttle, or burn against the exhaust. Other than that pull any computer related fuses or relays.
The early style brackets are suprisingly simple, and can be had really cheap at a junk yard.
Old 11-27-2006, 08:48 AM
Blue Bowtie's Avatar
Registered Offender
Re: 327 in '82 Elky
Your other option is to put some decent heads on the 327, such as '416s or similar. They'll flow better, have smaller chambers for better compression, and have the holes you need to mount the accessories. They, too, can be found cheaply in many junk yards.
Old 11-27-2006, 09:34 AM
Registered Offender
Re: 327 in '82 Elky
Old 12-01-2006, 03:35 PM
Re: 327 in '82 Elky
so,is the casting #s on the head between exhaust ports?been out of domestic cars for awhile-please excuse the ignorance......
Old 12-03-2006, 07:08 PM
silicon212's Avatar
Confoundingly Lucid
Re: 327 in '82 Elky
The casting number is a 6-8 digit (usually a 7-digit) number under the valve cover. It can be between valve springs or anywhere under the valve cover.
The castings themselves are usually referred to by the last 3 digits of the casting number (i.e. '492 is 3991492).
