Old 11-11-2006, 11:55 AM
miami3000gt miami3000gt is offline
wierd idle...
ok so i nocticed this today ...
when the car is in idle the rpms will drop from 1k to about 800 every 5 secs
its not a very rough idle but u can feel it , when it goes down and up again.
duno wut this could be
-im running on 3 new front plugs and 3 old back ones NKG
-i put in a fuel systems cleaner like 2 days ago into my current tank.
if that helps
Old 11-11-2006, 01:05 PM
Igovert500's Avatar
blue + red light magnet
Re: wierd idle...
probably dirty IAC. Do a search, you'll find plenty of threads. Normal idle should be a steady 700rpms. Also swap all 6 plugs, don't be lazy.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-11-2006, 08:38 PM
Re: wierd idle...
i am i just didnt have the time this week cuz my step dad has all the tools...
normal idle 700rpms mines is more like 900 - 1k
1995 mitsubishi 3000gt Base Model - working on her
Old 11-11-2006, 09:35 PM
sLADe781 sLADe781 is offline
Re: wierd idle...
Mine used to idle at about 900. Then my IAC went out. After I replaced it idles around 700 now...
Old 11-11-2006, 10:41 PM
Re: wierd idle...
how will u clean the IAC? pressurized air? is there like a guide thxs.
Old 11-11-2006, 11:38 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: wierd idle...
here is a guide
http://stealth316.com/2-isc-iac.htm
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-11-2006, 11:41 PM
X2Xtreme360 X2Xtreme360 is offline
Re: wierd idle...
1) Remove MAS
2) Get some electrical contact cleaner (wal-mart/autozone)
3) Spray away on the IAC/MAS electrical wire. Don't be afraid to spray 4 or 5 short bursts to drench it. Be sure to do both sides.
4) DO NOT touch the wire with ANYTHING! You will ruin your MAS.
Hope you have better luck than I did. If this doesn't fix the problem, you may need a new MAS.
Old 11-12-2006, 07:36 PM
Re: wierd idle...
ok so i check today and now my idle stays STILL right under the 1(not even 900)
but sometimes will go up
Old 11-12-2006, 08:23 PM
Re: wierd idle...
yea I have the exact same problem. Runs like sh** one day and runs great the next. I still haven't figured out what the problem is yet, but right now I would say it's your MAS.
Old 11-13-2006, 12:29 PM
Re: wierd idle...
so is it the MAS or the IAC?
Old 11-13-2006, 01:36 PM
Re: wierd idle...
I beleive their integrated circuits.
Old 11-13-2006, 01:57 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: wierd idle...
The MAS and IAC are completely different parts of the car.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-13-2006, 02:55 PM
Re: wierd idle...
I understand that but I guess I'm missing something. I keep hearing that the MAS and IAC on a 3000gt are combined. If they aren't then I would like the know where the IAC is.
Old 11-13-2006, 03:25 PM
Igovert500's Avatar
Re: wierd idle...
Forget the MAS for the time being and focus on teh IAC. Check the link provided in post 6.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-14-2006, 03:13 PM
Re: wierd idle...
Alright I was confused. I read the post, went to my car and followed the removal steps. Althought I couldn't remove the entire thing (it's in the manifold pretty good.) I took out the 3 screws and just disassembled that peice. I cleaned it, took it for a drive... it ran like crap. This morning I started her up, and it ran great... so I dunno if this is the end to my problem (the CEL went away too). But yea, miami, listen to igovert and read the link on post 6 if you haven't already, because it may help you.
