Camshaft type?
Do certain blocks use dif types of cams? Im looking at jegs trying to buy my new valvetrain parts but dont know were to start
![]() my engine is a 1981 Chevy 350 4 bolt. When I bought it had no valvtrain at all cept for the heads and springs, which I threw out. (not the heads, lol) Can I use a hydralic cam or is my block a roller or mechanical? or does it not matter. is one of the types best for performance? Should I just get the LT4 hot cam kit and not worry bout finding good parts? Will the LT4 hot cam work in my Gen I SBC?
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Re: Camshaft type?
Your block being a 1981 is not set up for factory rollers, so that rules out an LT4 cam without serious work. You're going to want to stick with flat tappet lifters.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: Camshaft type?
Re: Camshaft type?
Not particularly, but keep in mind that if it's mechanical (solid lifter), you will need to set the valve lash on each valve with feeler gauges, and you will need to periodically measure/adjust them. Unless it's an all-out race engine, you're better off with hydraulic lifters, which are set-and-forget.
Re: Camshaft type?
I would have been one very un happy camper if I blew the 600$on a LT4 hot cam kit and found it didnt fit/work. lol you wouldnt happen to know if the stock valve springs are 1.445" tall?
Re: Camshaft type?
Installed height is closer to 2 inches, actually in the area of ~2.050. The 1.445 might be a spring diameter for a certain type of spring. It could also be max compressed height before coil bind - where the coils touch.
Re: Camshaft type?
Do cam bearings need to be put in by a shop? my block doesnt have any in it right now.
Re: Camshaft type?
Re: Camshaft type?
Just my 2¢, but for anything I'm building in the future I'm going to strongly lean toward a roller, or at least direct-lube lifters and a HV oil pump. Even if the block is a plain old 2-piece RMS, no-dogbone/spider, and 2-bolt with cast crank, I'll be wary of using a flat tappet. The removal of antiwear additives from most engine oils is going to make life very tough for flat tappet cams in the future. Even some of the truck oils are reducing or eliminating ZDP, sulfur, and baruim based additives. Roller-cammed engines don't care much, but flat-tappets are going to wear faster unless you are very careful about the oil or additive you use.
Beyond that, rollers offer the opportunity to have greatly increased ramps, so stupid-big lifts can be had with a reasonably short overlap, so street manners are a lot more easily maintained. Aftermarket rollers have been around for decades, and are probably actually better than the factory setup for rotation control. |
Re: Camshaft type?
Wow, I didn't know they were modifying the oil to remove the antiwear additives. I've always used an HV pump on a rebuild (most of the time with a 35 psi spring, as in my car now), and I was leaning toward a roller setup considering my block is ready for one, but now I have more incentive.
Is this pretty much across the board (re: oil antiwear) or certain brands? I've always been a firm believer in Castrol GTX.
Re: Camshaft type?
yeah this is the argument people give for thier reason that they run diesel motor oil in their gas engines. the diesel oils apparently have more zinc in them that is a key antiwear thing to have
Re: Camshaft type?
Well thats gay! are they doing this to fade out some old technology?(like my flat tappet cam)
Ive always been a Quakerstate/Pennzoil/Amsoil guy. What does a roller block have that mine doesnt? Would I be able to get about 40,000 miles out of my flat tappet cam with the less additives? my block was about .002 over in each cylinder it doesnt have much wear left before needing a bore.
Re: Camshaft type?
In a factory roller block engine, there are three bolt bosses in the lifter valley, on the main oil galley, that the 'spider' retainer for the roller lifter locks, is bolted to. There are also two bolt bosses behind the timing cover for the camshaft retainer plate. You can go with an aftermarket type of roller setup (as Blue Bowtie says, these have been around for decades) with lifter pairs that are attached to eachother and a camshaft "button" that holds the cam back in the block.
Most aftermarket roller type cams are machined from billet steel - a steel rod in untechnical terms, and are sufficiently soft on the distributor drive gear that you MUST run a bronze distributor gear to prevent the distributor drive gear on the cam from failing and taking out the distributor - and oil pump. Roller lifters must be retained in the block and not allowed to spin - if one does, the damage is catastrophic.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. Last edited by silicon212; 11-13-2006 at 07:00 PM. |
Re: Camshaft type?
what are "racing oils" like royal purple, redline, and Mobil 1? this is all very new news to me, I had no idea bout this.
