Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-10-2006, 10:09 PM
94century's Avatar
94century 94century is offline
Noise
I have what sounds like a bearing noise coming from under the truck behind the front seats when driving it. Around 40 MPH is when it is worse. However after a few minutes of driving it goes away. I was told to check the center support bearing,they also said if it was a rear end noise it would not go away. It is constant whether cruising acceleraing or decelerating. It is an '88 3/4 ton 2wd with 454 and 14 bolt rear axle and two peice driveshaft. How does the driveshaft come apart? does this sound like a support bearing and how do I tell which one I have without pulling it apart, where would the part number be? Also I shook the driveshaft back and forth at the pinion, no play there, but when I shook it at the support bearing there was a very slight ticking sound, like metal on metal. Anyone help with some or all of these questions?
USS Carl Vinson CVN-70
1994 Buick Century
1988 Chevy Suburban C20 454
1989 GMC C1500 305
