Old 11-10-2006, 06:24 PM
jamesmetairie jamesmetairie is offline
why buy taurus=
i,m looking to buy a good used 2006 taurus.. i like taurus except for the old reputation of bad trannys . i get much better mpg,s and alot more quickness with some 3.1 litre g.m. cars. why should i buy taurus? give me some reasons to buy taurus.
Old 11-10-2006, 07:54 PM
TaurusKing TaurusKing is offline
Re: why buy taurus=
GM's have never had any issues??? If GM has been good to you, stick with it...
Old 11-10-2006, 07:57 PM
MyTaurus8AChevy's Avatar
MyTaurus8AChevy MyTaurus8AChevy is offline
Lightbulb Re: why buy taurus=
  • If you get one with a Duratech engine the tranny will be incredibly good.
  • If you're into Consumer Reports, their customers have consistently rated the 2004-2006 taurus 4 or 5 stars (out of 5 stars) across the board. I think the only GM cars rated like that was one Caddy and the Vette.
  • With Yokahoma YK520 tires it will ride like silk and handle like it's on rails.
  • Our Duratech runs like a raped ape, and we get great MPG.
  • All things being equal the car is very easy to work on. Very well engineered.
Old 11-10-2006, 08:15 PM
Re: why buy taurus=
duratech engines?? which ones had the duratech? is it only taurus,s with duratech. btw , i read in carsurveys.com some very unhappy taurus owners . i am impressed with the safety ratings of taurus for the last few years.
Old 11-10-2006, 08:43 PM
Smile Re: why buy taurus=
No the Sables had the Duratech too. For the Taurus I think only the SES and SEL models got that engine, but I'm 100% about that. I've just never seen a SE with that engine, but once you drive one you will never turn back
Old 11-10-2006, 08:51 PM
Huney1 Huney1 is offline
Re: why buy taurus=
The reason most trannys have problems is because the owner does not adhere to the owners manual maintenance schedule. Or they take it to a yo-yo to get the tranny fluid changed or flushed and they put Mercon III in it instead of Mercon V. A flush is $100. at the Ford dealer and I think a change is like $60. bucks. The general consensus is change or flush it at 60K miles and flush it at 100K miles. I have an 03 SES Vulcan engine regular old pushrod engine 45K mi on it and I changed the fluid at 40K mi and plan to have it flushed at 60K. 'Prolly overkill but I'd rather spend a few bucks keeping the tranny in tip top shape than rebuild the tranny for about $1,500. bucks. DUH? Now, that is a no brainer if I ever heard one, 'cause like the man said, pay me now or pay me (MORE) later.
The 06 tranny takes Mercon V which, unlike the others, is part synthetic, so make *darn sure* they do not put anything but Mercon V in it. Let a word to the wise be sufficent.
In 45K miles I put a new $65. battery in it, PCV valve and gasket $5.00, one oxygen sensor $41., rebuilt the starter $138, and put a set of Kuhmo tires on it for $210. and a new serpentine belt this week end $27. and to my way of thinking those are maintenance items anyway.
Around town 21 mpg and never drove it on a road trip. I like to accelerate fast and do not baby it so I figure for the way I drive 21 is good. Friend has 125K road miles on a 95 and claims other than regular maintenance items never had a minutes problem with it.
We've had three Tauri and I believe if you take good care of them they will take good care of you.
Old 11-10-2006, 09:30 PM
Yep, people try to cut corners and then they whine and blame the car when something goes wrong. That's why I take what I read at places like carsurveys.com with a grain of salt Most modern well designed cars (like the Taurus, Honda, Milan, ETC.) will treat you well if you treat it well, and in most cases that is just using common sense
Old 11-10-2006, 09:41 PM
Re: why buy taurus=
consumer guide says all SEL models had it and SES models were offered it as option. but no SE models had it. jim.
Old 11-10-2006, 10:14 PM
Re: why buy taurus=
from 2000 on up the base model did not have it. the LS "premium" had it. the plain LS was offered it.
Old 11-11-2006, 06:20 AM
e_powers e_powers is offline
Re: why buy taurus=
another way trannies die in tauruses is if you let the wheels spin like burn outs and neutral drops. i had a 96 sable with the original transmission that went 245,000 miles.
starting to love my 93 ranger w/3.0 5 speed.
Old 11-11-2006, 10:17 AM
Willyum Willyum is offline
Re: why buy taurus=
Sway bars, adjustable pedals and the duratech were not offered the last couple of model runs.
Old 11-11-2006, 10:32 AM
Question Re: why buy taurus=
How hard would it be to change the tranny fluid/ filter yourself in a 2004 Taurus? I'm guessing it's more messy than hard.
Old 11-12-2006, 06:42 AM
Re: why buy taurus=
drop pan change filter replace pan torque bolts correctly. refill the tranny back to level then get a buddy in the cab get a big container remove hose to tranny cooler and put container under hose start engine up and pour new bottles of atf in the tranny tube till the color of the atf fluid out of hose of tranny cooler matches the color being poured out of the bottle.tell buddy to kill engine. button it back up. then check level and refill as needed and start it back up and check for leaks. drive it around check for leaks. get a beer to celebrate.
but word of warning. never let the tranny runn out of fluid. and dont drink beer till you are done.
Old 11-12-2006, 06:46 AM
mwt878991 mwt878991 is offline
Re: why buy taurus=
As the Taurus was relegated to pretty much fleet sales for model year 06 and 07, I don't believe you will find one with a Duratec. I am pretty sure the last year it was offered was 05.
Mike
Old 11-12-2006, 09:26 AM
Re: why buy taurus=
Fluid change/flush: Ford dealer here does a complete flush for $100. and I think Mervon V runs about $3.75 a qt and you need 15 quarts, so for the DIY hassel and mess you save about $44.00 and at my age it ain't worth it. Most of the time they have oil & filter change for $15.00 and rotate tires for $10.00 so for my money $25.00 is a good deal.
I asked a tranny shop what they charged and a filter and fluid change is $60.00 and that only replaces about six qts of fluid, so for another $40. I get 15 qts new fluid so I'll go that way. I mean, go figure; Extra 10 qts would be about $37.00 and to me well worth the extra forty smackeroos.
Whoever does it, make darn sure they use nothing but Mercon V.
My compliments on taking care of your Taurus and I hope we all get the long life out of our tranny like e_powers did: "i had a 96 sable with the original transmission that went 245,000 miles."
