Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-10-2006, 04:53 PM
bgreer5050 bgreer5050 is offline
3.2L DOHC Cam Gears
The books I have show how to align the Timing gears for the purpose of installing a belt, but I need help with how to install the gears onto the shafts.
Can you help me with this? I need to install the gears onto the camshafts and there is more than one way for the cam gears to go on.
Help. Please.
Old 11-10-2006, 05:53 PM
rodeo02 rodeo02 is offline
Re: 3.2L DOHC Cam Gears
I dont have a service manual for this, but if the cam drive sprockets have been removed, I believe you will have to:
1) Remove the cam covers
2) Find top dead center for cyl #1 and set the intake/exhaust valves per the manual, then install the cam drive sprocket.
3) Same procedure for the even bank. set #4 (or whichever) to TDC, set the cams, install the sprocket.
Basically, once you loose the orientation of the cam sprockets to the crank sprocket, a lot of work is involved! This is why I suggest to everyone to mark the positions of the pullies with a paint marker or the likes BEFORE you remove the belt.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-10-2006, 08:30 PM
surferfletch surferfletch is offline
Why were the cam gears removed? Just curious.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
