Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 11-10-2006, 04:26 PM
987qqq 987qqq is offline
how connect tachometer to 94 Tercel
To connect a tachometer to my 94 Tercel my manual shows a tach with one lead going to the positive battery post, one to the negative post and a third lead connecting to a jumper wire connected to the data link connector. My tach only has two leads. If I need a tach with three leads where can I get one and can I use a paper clip as a jumper wire? Thanks.
Old 11-13-2006, 01:41 PM
KimMG KimMG is offline
AF - Advisor
Re: how connect tachometer to 94 Tercel
What are the two leads from your tach suppose to be connected to? I would not use a paper clip for a jumper wire, it is not insulated and it would be difficult to attach the proper terminals. Use the proper guage automotive wire.
Old 11-14-2006, 09:41 PM
My manual shows two leads coming from the positive tach connection, one of which connects to the positive battery post and the second to the negative battery post, and one lead coming from the negative tach connection going to a wire inserted in the diagnostic unit. Thanks.
Old 11-15-2006, 02:37 AM
AF - Advisor
I think you misunderstood my question. You have a tach with two leads. Is this a tach from another vehicle? Or is it an after market one?
I am assuming the manual you are refering to shows the wiring for a stock tach. Your two wire tach may work, but it just has to be connected differently than the three wire. Do you know what the two leads went to?
I have a tach with two leads, one lead goes to the coil and the other goes to a switched power source. The tach is grounded through the case so I had to make a wire with two eye terminals, one end connected to the mounting strap for the tach and the other end I attached to the body of the car.
Old 11-15-2006, 02:43 AM
Sorry, the tach I'm talking about is a diagnostic tach, not one that is installed in the vehicle. I just want to check the rpm and adjust it occasionally.
