| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Trouble Codes
Does anyone know of a website or something that you can see what trouble codes you have mean? I have 3 that i need would like to know what they are.
![]() ![]() SOLD '97 GSX EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels '05 blacked out f150 FX4 |
Re: Trouble Codes
Codes that the car gives you with it's own reading system or codes pulled with a scanner? There are two different ones. If they're with a scanner, just google "eclipse <code number here>"
Re: Trouble Codes
You could get some help right here if you would give up your code no. We promise not to tell anybody what they are. ![]() BUT I BET ONE OF THEM REFERS BACK TO THE K&N FILTER
Re: Trouble Codes
thanks a lot
Re: Trouble Codes
i have these 3 codes:
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control P0170 Fuel Trim Malfunction (Bank 1) P0551 Power Steering Pressure Sensor Circuit Range/Performance can anybody tell me what exactly they are and how to fix them?
Re: Trouble Codes
Is the engine getting up to operating tempture? Does the PCM read the right engine tempture?
Re: Trouble Codes
1) Does the car get up to normal operating temp? You might have a thermostat stuck open, which would cause it to run cold constantly.
2) How does the car run? Gas mileage okay? 3) Check the power steering system and make sure everything is plugged in. I've never seen the power steering code before and I'm not on my laptop so I can't look it up. I'll see what I can find when I get on my laptop. |
Re: Trouble Codes
my gas mileage is only around 18 mpg so... and the running temperature seems to stay a little cool. Would a thermostat cause that and where is it located?
Re: Trouble Codes
Yeah the theromostat would cause it to run cold all the time. It's in the thermostat housing off to the left front of the head.
