Old 11-10-2006, 10:07 AM
qualetale qualetale is offline
99 3.1 vin M ?
99 3.1 vin M needs replaced. Part selectors cross ref 2000+ 3.1 VIN J and K-"exact swap" or extra work? also lots probs of head gasket on 3.1, but is it caused by the aluminum head on vin J K?--not sure if M alumninum.
thanks
Old 11-10-2006, 10:09 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 3.1 vin M ?
Welcome to AF.
How many miles and what problem are you having? LIM gaskets are a common problem.
Timeslip 08/12/06
AF Community Guidelines
Old 11-10-2006, 10:35 AM
Re: 99 3.1 vin M ?
Motor shot--must replace--just ?? of vin M interchange with J and K of 2000+
Old 11-10-2006, 10:45 AM
BNaylor's Avatar
Re: 99 3.1 vin M ?
The 3100 Vin "J" replaced the Vin "M" in the 2000 model year. Not sure of all the differences but the swap will probably work at least between the 3100 engines. As to going to Vin "K" which is the Series II 3800, no doubt the engine will fit but there will be logistical problems. For one you will need the PCM replaced.
What transmission do you have? The M13 4T60E or M15 4T65E. Check the SPID label on the back of the trunk lid.
Also, there are wiring harness differences.
Timeslip 08/12/06
Old 11-11-2006, 09:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 99 3.1 vin M ?
The upper and lower plenums are different between the vin-M and vin-J 3100's, as well as the cylinder heads. There will be many headaches trying to get an EGR valve, heater hoses and such to make the Vin-J fit in a Vin-M car. IMO, other than the crappy intake gaskets GM used on them, the vin-M is a superior engine to the vin-J. It seems that the vin-M can survive an intake gasket failure, where the Vin-J almost always cooks a head gasket when the intake gasket fails. As bnaylor stated, the vin-K will obviously fit, but it's a 90 degree V-6, where the 3100 engines are a 60 degree V-6. Motor mounts, engine wiring harness, PCM among other things are different. You'd be best off doing an apples to apples swap, Vin-M to Vin-M.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
