Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-10-2006, 09:26 AM
victorvaj victorvaj is offline
My Transmission Problem
Hi, I drive a '97 Mitsubishi Eclipse RS w/ a 420A engine and I have an automatic Transmission Problem. It seems that my transmission will slip on certain occassions, while it changes to the next gear. This often happens right after i release the gas pedal (mostly around 40-70 mph) and going up or down hill and therefore causes my engine to go up to 5000 RPM just to go at least 40 mph. I went to Cottman's Transmission service, and had my engine scan, and it came back that I have an idle problem and EGR (engine solenoid position problem) and TPS (throttle position sensor) are positioned high and the valves are out of range. I researched these parts for my car and it will cost me around 500-600 dollars in parts and perhaps another $300 in installations. What seems to be the problem w/ my transmission slipping? I need some help.
Old 11-10-2006, 09:48 AM
Killa's Avatar
Killa Killa is offline
Re: My Transmission Problem
Hi welcome to the forums . When is the last time you change your tranny fluid ? pull the auto transmission dip stick, and see what color its.
about your egr and tps, you can find it on ebay alot cheaper. and its easy to install, buy yourself a hayhes manual ( at auto part, autozone , advan auto part ), and learn how to do those thing yourself, save you alot money.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-10-2006, 11:25 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
The only advice I can really give is that replacing all those parts will most likely not fix your transmission problem.
Also, those two parts should not even cost you $200 to replace, and installation you may want to try yourself.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
First off, welcome to AF, and thanks for posting in the correct subforum, most people wouldn't do that, so I thank you.
Regarding the tranny problem, first do like Killer said, check the tranny fluid. Make sure the car is at normal operating temperature and cycle through the gears with your foot on the brake. 1-2-D-R-N-P, keeping it in each gear for 3 seconds. Then get out and check the fluid. If it's a nice clean red color and it's up to the dipstick, it's good to go. If it's kinda brown and smells burnt, it's time for a tranny flush.
About the idle problem, make sure all of your vacuum lines are connected. Also, EGR stands for Exhaust Gas Recirculation and I don't know if I've ever seen an EGT problem cause a shitty idle, it's usually something bigger than that. The TPS could cause a shitty idle, but it's usually leaning more towards the IAC (Idle Air Control). First see if you can fix your tranny problem and then come back and we'll see about your TPS sensor.
EDIT: I just notice you didn't say anything about the car running shitty. Does it run okay besides the tranny problem?
95 Talon TSI AWD
97 Eclipse GST
Old 11-10-2006, 11:32 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
its crankwalk....lol
i had a shitty idle too, but since ive replaced my exhaust manifold gasket it purrs nice.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
