96 passport- hole in engine???
I just bought a 1996 Honda Passport from a lady who could not afford the bill at the dealership for work she had done on it. The tranny was in the back end, and there werent any bolts for that. Also, there was a coolant leak. The removed the tranny because they said that the leak was coming from a hole in the block that was behind it. I brought the car to a tranny shop and they were going to install it, but I looked at that "hole" first. It appears to be factory. I went to the dealership and looked through their books and found that it is supposed to be there, but no one knows what it is for. I am really hoping to get this fixed, but I need to figure out the problem. Can anyone help me? The hole is pretty small, like a weep hole. It is up higher on the block, just inside the tranny-mounting spots, inside some of the casting "ribs" on the block. Does anyone know why coolant is leaking from that hole?!?!? No one I talk to does, PLEASE HELP!!!!
- A Newb
if you don't know what your doing... buy a CRX. you will feel better in the morning. 88' CRX DX Si 5 spd conversion d16z6 swap 15" GS-R wheels DC exhaust A'pexi V-AFC ZC hood (best thing ever) AEM cold air 14b turbo setup un-tuned 285whp 96' Passport EX don't know why, but I got it CHEAP! |
Re: 96 passport- hole in engine???
Give us some details on your first post.
Engine size? Auto or manual transmission? Can you obtain a digital photo of the hole and post it here? Tom
'65 Chevy Malibu SS '06 Pontiac Vibe (a dead deer fits nicely in the back) '04 Ford Escape GMC S-15 4WD '57 Chevy 210 post sedan '51 Ford F2 pickup Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD. |
That's probably where I had my coolant leak. It's a 25 cent freeze plug. I tried for a couple of weeks to find it, but I finally had to take it to a shop where they pressure tested it. $2 in parts but $500 in labor (or something like that) to drop the tranny and access it.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2 1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs 1996 VW Jetta GLS 2.0L 5 spd |
Not surprised the dealer didn't want to help...
![]() ![]() there is a pic of the hole, and the other is me pointing to where it is. That image is the back of the engine, where the tranny is mounted. The hole is kinda up high on the block. Also, it is the 3.2 liter v6 and it is an auto tranny. Let me know what you think. THANKS!!!!!!
Well that's not what I expected it to look like. I expected it to be bigger. I just had the shop fix it, so I didn't get a good look at it. Now I'm not so sure...
i think this is going to be one for 2eyefish.
2006 liberty 3.7 6speed manual 1999 cherokee classic 4.0L 1991 wrangler yj 2.5L 2001 caravan 3.3 auto 1995&1992&1994 camry 2.2L SOLD 1991 silverado 1500 SOLD 2000 rodeo SOLD
Did a casting plug go there? And fell out, or worse IN?
That photo was hauntingly familiar of a Mazda I owned in 1985. A casting plug - Not a freeze plug - came loose and coolant went everywhere. Overheated the engine (happened on the highway) and $1100 later the engine ran again. Very poorly, was never the same afterward, burned oil, etc. The dealer technician had never heard of it happening before. Hope this isn't the same scenario. Maybe it's something a whole lot more friendly to the engine. Tom
Yeah, casting plugs are frequently mistakenly called freeze plugs. Glad you pointed that out. Don't know exactly if my leak was due to a freeze plug or casting plug, but it sure communicated with a coolant passage in the block. From that limited view, it doesn't look like there are any other plugs between the tranny housing and the block?
well what I was waiting to hear was that it is a drain hole for the intake valley. I have heard that these engines have a chronic coolant line leak problem underneath the intake manifold. To test this theory, I dumped a jug of water in the intake valley and a river of coolant flowed out from under the car. I couldn't get under there to look right at the hole while I dumped it, so I am not totally sure. Either that, or it is a freeze plug that popped, and then that's the drain for it. If that's the case, then a freeze plug popped AND I have a really bad coolant leak on top of the engine. I really was hoping that someone would just be like "that hole is a blah blah blah....." and know for certain, so I did not have to go through all the trouble shooting or pay a mechanic to lie to me and charge me WAYYYYY too much. I dont know, keep giving me ideas and I will be sure to post what it was so you all can store it away as an "I know what that is...." thing. Thanks!!!!
To me it looks like you had the right idea. Looks like a weep hole. I thought maybe for the area under the intake, but as I dont know for sure I didnt want to confuse things.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
When I had my leak, I fixed the o-ring problem in the external coolant plumbing at the top of the block first. Still leaked at the back of the engine. I took it to the shop and they told me it was no longer leaking up top, that what I'd done up there was fine. They then came up with the freeze plug between the tranny bellhousing and engine. That seemed to fix it. I may not have gotten a full/truthful story. Just some more info to hopefully help you.
This much coolant will pool between the heads without any drips below the engine. The way it was explained to me on this board was that it just spills over the top at the rear of the engine, which seems plausible...
So you had a leak there AND a freeze plug pop??? Or did you have a coolant leak for a while and then the freeze plug all of a sudden went out. There was no coolant leak before this happened. I just kinda find it odd that two problems would present themselves at the same time. I know it is possible, but just unlikely. Do you know where that plug is at? I could take a look at it tomorrow before they put the tranny in. Let me know. Thanks!!!!!
It all happened at the same time. You have me wondering now if they ever really had to drop the trans. That was a pricey repair. And I never did see the hole which was plugged. They just called me to tell me it was fixed after I authorized the repair. I took it to the shop after I fixed the coolant leak up top. I still had coolant dripping below where the tranny meets the block even though I no longer had coolant at the top of the block.
