Old 11-09-2006, 11:23 PM
2.4_Z 2.4_Z is offline
A/C comes on when heater turned to defrost
I just bought my '99 Cavalier Z24 and when I turn on the selector to defrost setting on the heater my a/c light comes on and I can hear the compressor. Is this normal?
BTW this is my first post and thanks for all the other info on this forum. I will be a regular for sure here!!!
Kris
Old 11-10-2006, 02:29 AM
muff34 muff34 is offline
Re: A/C comes on when heater turned to defrost
Kris
yup they`re suppossed to do that .keeps the a/c compresor lubed and operational
Life Is A Highway ,Enjoy The Ride
Old 11-10-2006, 08:25 AM
Phife Phife is offline
actually it has nothing to do with lubing the AC..
It turns on because AC can remove moisture from the air thus helping with defrost.
But since the heat selector is on hot it heats the air back up after the moisture was removed and the air was cooled.
Old 11-10-2006, 09:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Kris
Welcome to AF on your first post.
No problem no sweat no worry. They all do that.
It is the way they are made to take the condensation off of the windshield and door glass.
Good luck with it
MT
Old 11-10-2006, 10:05 AM
Thanks Guys!! That takes a load off me. I thought that I might have to spend some big bucks to have that fixed. Ah, well on to other issues. Thanks
'99 Z24 5 speed
Old 11-10-2006, 10:29 AM
opps guess I dropped the ball on this one. I thought a/C compresor could use some lubing/cycling to keep it from seizing up when not in use. Seeing as how a/c is not used in winter months ,I figured maybe automakers would design system so that it would cycle even when a/c is not required at the time to prevent such seizing problems. Guess cars with out a/c do not defrost as well
