Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 11-09-2006, 11:03 PM
oldsmess oldsmess is offline
Oldsmess
My 1993 olds regency ninety eight,the security light is on and after three mins.it still willnot start,ive cleaned the resitor on the key and just inside the switch,we connected a battery to my batt.and it still will not start what is wrong,please help,my wife is getting on my back a bout it. help me.
Old 11-10-2006, 06:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Oldsmess
Try resetting the system by turning the key on for 10 minutes and shutting it off for 30 seconds. Repeat and after the third 10 minute interval the car should start. Also try another OEM key to see if that will work. Sometimes the chip in the key will go bad and cause this issue.
Welcome to AF!!
Old 11-13-2006, 03:17 PM
Re: Oldsmess
well i did take a real good look at my keys and my little bro came over and i took a good look at his keys,and the risitor prongs sticking out on each side of the chip on his key are really good,but the points on my chip from my keys look like they have been filed down.my wife got a ride to the gm/olds place here in my town and they said if i have tried everything even the relearn steps,and it still will not start then it is mostly to be the ignition switch,so is there a special way once i get the steer wheel off and the plate removed for removing and installingreplacement ignition switch?Thanks
Old 11-13-2006, 03:24 PM
Re: Oldsmess
