2001 GAGT Fuel filter
I searched...and failed. As always.
In-tank?? In-line?? Easy replacement?? I think mine needs replaced. Best one to buy?
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Re: 2001 GAGT Fuel filter
Its In the line above the rear axle, up on the body.
One end is a nut(not sure on the size) the other has a plastic coupler that plugs into the line fitting. They sell/rent a tool that squeezes that plastic piece then pull it straight out. I usually have better luck with plyers. Make sure and use some old rags when you loosen the filter. it will drain quite a bit of fuel, more if you drop the hose lower then the tank. You can drain the pressure off from the shrader vavle on the passengerside back fuel rail. I tend to buy Napa AC delco, my local dealer had them cheap for a while but they're $20 now. ![]() Napa runs about $15. Just thought, while you are under thier, check all the hoses for cracks and make sure the clamps are tight. I've seen/had them get loose and cracked causing a small leak.
1999 Grand Am SS 3.4 OHV
Sounds exactly like the Trans Am's filter.
Thanks!! Thinking about it. How is the GM filter?? My girl can get it a hair over cost.
Gm is fine, thats what I'd been using in the past.
I was paying $10 at my local dealer, they are the same as the ones they carry now but the price has doubled now
