Old 11-09-2006, 06:56 PM
MyTaurus8AChevy's Avatar
MyTaurus8AChevy MyTaurus8AChevy is offline
Question Airbag light flashes
We're installing a remote start in a 2004 Taurus. Everything seems fine but now the airbag light in the dash is flashing once, then 8 times. Does anyone know what this means, and more importantly, how to correct it? We tried to disconnect the battery to reset the computer, but that did nothing as far as the flashing light goes, and it still flashes
Old 11-09-2006, 09:35 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Airbag light flashes
You are seeing a Lamp Fault Code of 18, per the service manual:
The air bag electronic crash sensor (ECS) module supports features which are not used in Taurus/Sable vehicles. The wiring harness pins used by the ECS for these features are normally left disconnected in Taurus/Sable vehicles. If the ECS detects a connection to Pin 3, 4, 5, 6, 8, 9, 10, 11, 16, 18, 20, 23, 24, 25, 26 or 27, it will store a diagnostic trouble code (DTC) B1871, B1877, B1878, B1879, B1881, B1882, B1883, B1884, B1885, B1886, B1889, B1890, B1901 or B1941 in memory and flash a lamp fault code (LFC) 14, 17, 18, 25, 27, 41, 46 or 47.
Possible Causes
An unexpected feature present could be caused by:
l a wiring harness fault causing connection to a normally unused ECS pin.
l an internal ECS module fault.
-Rod
Old 11-09-2006, 09:43 PM
Lightbulb Re: Airbag light flashes
Thanks Rod. We fixed it. Turns out it was caused because the radio was not plugged in It seems to be OK now. We've had the radio out many times before without this happening, so all I can figure is that it's seeing the Securilock bypass module for some reason when the radio is not plugged in.
Old 11-10-2006, 09:46 PM
shorod's Avatar
SHO No Mo
Good for you! Thank you for the follow-up post.
-Rod
