Old 11-09-2006, 06:23 PM
hail2pitt98 hail2pitt98 is offline
'03 Rear brakes and rotors
I need to replace the rear pads and rotors on my '03 1500. Is this straight-forward, or will I need to 'back-off' the parking brake from the rotor (like on my wife's Explorer)? When I replaced the front rotors, it took forever to get the rotors off the truck. Also, thoughts on opening the bleeder when compessing caliper, necessary or not? Appreciate thoughts from anyone on this job.
Thanks
Old 11-09-2006, 07:12 PM
maxwedge maxwedge is offline
A990 racer
Re: '03 Rear brakes and rotors
Welcome to AF. No external parking brake adjustment on these trucks, hope the e brake shoes are not worn into the rotors, which was an ongoing problem, I would get a hose and fresh fluid in a glass jar, attach to bleeders when collapsing the pistons.
Old 11-09-2006, 09:04 PM
Thanks for the info Max.
Can you please clarify why fresh fluid is need in the glass jar? I would assume the existing brake fluid would bleed out when compressing the piston. Is it to keep air from entering back into the system before the bleeder is closed?
Thanks again.
Old 11-10-2006, 09:13 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
You should be able to take a set of pliers and squeeze them shut. Just make sure you do not slip your grip you can damage the caliper.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-10-2006, 11:53 AM
alblogg's Avatar
alblogg alblogg is offline
Yes I love GM's E brake setup.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 11-10-2006, 11:55 AM
Yea me too.. especially when they do not work anyways.. When I bought mine brand new in 2000. The E-brakes were never enough to hold the truck still while in park.
Old 11-11-2006, 02:34 PM
alblogg's Avatar
Mine on my '99 Blazer has always worked liked a charm (knock on wood) but my boy has a '01 'Hoe never worked since he had it he's just waiting for the next brake job to change them, we did a set on a Blazer and it is no fun job. I think the idiot at GM or Dana or Bendix, Rockwell should have to help two people a month for twenty years for that design.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 11-11-2006, 04:57 PM
muff34 muff34 is offline
compressing the caliper . could you not just unscrew the cap on the resevoir to allow fluid to come back into with little resistance ? that`s what I`ve done on other vehicles.
muff
Life Is A Highway ,Enjoy The Ride
Old 11-13-2006, 05:53 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
On the 02 model , the rear parkbrake can can be adjusted for wear . It has a screw out bolt with a spring holding it firm to expand the shoe . But you have to take the rotor off to get to it . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 11-13-2006, 08:06 AM
I will have to look into that.. if that is all it is, then maybe I can use my ebrakes again.
