| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Need Help!!!!!!please!!!
Ok i have a 1995 Eagle talon esi n/t fwd , i had to put a new fuel rail on it so i did the pressure relief steps and took off the old one then just put the new one on its a stock rail. I got everything hooked up right and went to start the car nd nothing , i checked the coil for spark no spark and i have no power to the fuel pump what did i do wrong and how can i fix it ...i need help so i can drive this car
Re: Need Help!!!!!!please!!!
Check fuses? Did you remember to plug it back in?
plug that bitch back in!!!
Did you re-do everything you disconnected in the fuel pressure relief steps?
i didnt pull any fuses , i re connected every wire and did the fuel relief procedure steps i was suppose to , but the fuel pump and coil just shut down
Check the connection of the cables at the battery. Is the battery dead?
the connetion is good the battery is charged the motor cranks but no spark or fuel pump
I don't know what you did but for me the "pressure relief steps" involved me taking off the gas cap. So the fact that your fuel pump isn't working makes NO sense at all. Tell us what you did to relieve pressure.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
i did what my manual told me to do , take off gas cap disconnect fuel pump connector (i hooked it back up to ) started engine and run it till engine stops crank motor make sure fuel is gone
How do you know that you have no fuel? Did you do a pressure check or what? Did you remember to plug the injector harness back in?
i know i have no fuel bc the fuel pump is not kicking on
did you plug the pump back in for sure? you may have unpluged the pump from inside the tank, when you pulled off the harness... i doubt it, but i would go ahead and pull the pump out and makesure that had a good connection, then just redo everything you just did... the pump worked before you touched anything right?
I have a feeling it's going to be something really really dumb, or you fucked up something major. Have you tested for power at the pump connector yet? Just start testin shit man, power at the pump. If that checks out, check pressure at the rail, if that checks then check power at injectors, if that checks then you should have fuel.
i went checked the connector there was no power going to fuel pump or coil when trying to crakn over motor
