Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-09-2006, 04:01 PM
Killa's Avatar
Killa Killa is offline
Help indentify which is right way to install TBS !!
Hi my car have crazy TB respond, like when Im driving it bound between 800 to 2k, and then it make my car jerking bad. So i have to unplug the TBS and adjust with biss crew, then it it idle and work fine. no more boucing rpm or jerking when driving any more. it usually happen when I begin to move the car, or try to slow down.
This happent after I was take out my TB and changing the TB shaft seal. I take out the TBS and when I install I forgot how to screw it in, look like you can crew the bolt in both way. take a look at pix 1 and pix 2 and tell me which one is install right. Pay attention to the bolt that tight the TBS in. # 2 is how i install before then those boucing rpm or jerking when moving the car.
#1 I install the top bolt, it was on the left of the TBS, and botton bolt was on the right of the TBS.
#2 The top bolt was on the right of the TBS, and bottom bolt was in the left of the TBS.
Can you guy match this with your car, which one is the right way to install the TBS please thanks.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-09-2006, 05:43 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Help indentify which is right way to install TBS !!
killer, you are suppossed to check the voltage with a multimeter(sp) i dont know the exact specs, but check on tuners. or vfaq, should be under 1g tb swap.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 11-10-2006, 08:12 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
This is exactly why I love having dsmlink, all you have to do is twist the TPS untill the sensor shows .63v on the laptop.
DSM geek
Old 11-12-2006, 03:02 PM
Killa's Avatar
Hi I check and ajust with the ohm meter. Here a few question
http://www.plymouthlaser.com/tps.htm
when I hook up 1 and 4 my ohm read 4.89 ohms, and Plymouthlaser.com told me it should read 5k when the throttle close, is between 4.89ohms and 5k any different ?
and when I hook up 2 and 4 it read 9.6k, I cant adjust the TPS to 9k exactly. is that ok ?
GM FOR LIFE !!
95 camaro lt1
