Old 11-09-2006, 03:18 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
smoke?
so now the car smokes.
it is white. but very moist like water.
smells like gas not oil. i know i'm running rich.
it comes out just lil at idle, and when i give it gas more comes out. if i let off the gas in gear or idle the smoke stops.
after running till op temp i drove it around. the whole smoke thing happened so i stop at a gas station. and let it run at idle for like 3 minutes. the smoke stopped. so i got in and drove a lil more. the smoke was still coming out but not as bad.
so what do you guys think? do i just need more break in miles or did something bad happen?
thanks in advance.
-tony-
2000 honda s2000
Old 11-09-2006, 06:38 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: smoke?
I say its just condensation. Was the smoke more white and puffy like chimney smoke or more steamy like boiling water? Check your plugs and maybe lean the motor out a little. Make sure your timing is perfect.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 11-09-2006, 07:32 PM
Re: smoke?
the timing is perfect.
the plugs are good.
how do i lean the motor out?
it's like a mix of both. when i step on the gas it's puffy smoke, but dissipates quick. when it's at idle it's steamy smoke.
i'm going to get the valves adjusted again tomorrow to make sure it's not oil leaking in. the head gasket is good. nothing leaking out. also going to get a compression test tomorrow.
if that doesn't fix it then i'm gonna get a big sticker that says "THE FOG MACHINE" lol.
-tony-
2000 honda s2000
Old 11-09-2006, 08:42 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: smoke?
the plugs are good.
That sounds like one of two things:
1. Burning coolant
2. Hot air from the exhaust hitting the cold air on the outside. Don't forget, H2o IS a byproduct of the chemical process that happens in the catalytic converter.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 11-09-2006, 08:45 PM
Re: smoke?
how am i burning coolant but not oil?
i live in the desert so it stays kinda warm. and i'm a lil slow on the rest of #2. i ain't the smartest guy in the world.
-tony-
2000 honda s2000
Old 11-09-2006, 10:29 PM
viper-blue's Avatar
viper-blue viper-blue is offline
Re: smoke?
I'd say your burning coolant to..the white smoke is a give away...you just rebuilt that engine right? if so maybe you have a small leak in between cylinders? enough that coolant can seep into the cylinder. Or the headgasket is damaged by one of the coolant passages and is trickling into one, or more cylinders. Being that your in the desert bam bam's #2 doesn't seem very likely
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 11-09-2006, 11:02 PM
Re: smoke?
when i first noticed the smoke, i went and retightened the head bolts. you know just in case. i was there when the head gasket was put on and when the head was installed. i did it my self. i know the gasket isn't damaged.
-tony-
2000 honda s2000
Old 11-09-2006, 11:13 PM
bambam89lx's Avatar
AF - Advisor
Re: smoke?
You can burn coolant without burning oil.
You could also be leaking coolant into the intake manifold through one of the hoses.
Does it smell sweet? Here's a true test...but be careful. If there is liquid inside your tail pipe, taste it...but DON'T swallow it. It's not a big deal...just taste some on your tongue and then spit it out. This is the test I use to see if something is either water or coolant when it is leaking or burning. It's not politically correct, but it works. Just make sure you DON'T swallow coolant as it is poisonous and can kill you.
What headbolts are you using?
What headgasket?
what block/head combo?
what torque specs/sequence did you use?
Old 11-09-2006, 11:45 PM
Re: smoke?
What headgasket?
using arp b16 headbolts
buddy club b16 head gasket
jdm b16 block and head
stock torque specs and sequence
-tony-
2000 honda s2000
Old 11-10-2006, 07:00 PM
bambam89lx's Avatar
AF - Advisor
Re: smoke?
That all checks out fine there....you do the "taste" test yet to see if it actually coolant?
Old 11-10-2006, 08:01 PM
Re: smoke?
yeah i tasted it tonight. kinda like cjicken. lol
taste like oil. so the shop was closed so tomorrow when i can get the valve clearence tool then i can redo the valves and check compression.
-tony-
2000 honda s2000
Old 11-11-2006, 01:23 AM
bambam89lx's Avatar
AF - Advisor
Re: smoke?
Oil? That would be a grayish-blue smoke then.
Old 11-11-2006, 02:43 AM
Re: smoke?
no the smoke is definitly white. maybe it was just the residue i tasted.
either way it tasted like shit.
the shop i use/work at is open tomorrow so i will definitly get a compression test on all cylinders.
-tony-
2000 honda s2000
Old 11-11-2006, 02:45 AM
Re: smoke?
what hose do i need to check to see if it is coolant coming into the intake manifold?
-tony-
2000 honda s2000
Old 11-11-2006, 11:19 AM
viper-blue's Avatar
Re: smoke?
I'm not sure how many coolant hoses you have on the bseries intake. Personally I would just make sure your intake gasket is intact incase coolant is seeping in through the coolant passages in the intake, right into the combustion chamber. I'm not sure what bam bam meant about the hoses...you would have to have a leak directly in the intake for any leaky hose to be a problem right?
