Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-09-2006, 02:51 PM
1990 Suburban 1990 Suburban is offline
1990 Burb Gear Ratio Change Killed Gas Mileage
HELP,
Ever since the ratio change in my 2WD 1990 Suburban, the mileage has been worse. I started out with a 3.73 gearset and was averaging a solid 16-17 MPG. Since having the rear diff replaced with a 3.42 gearset it's been a steady 12-13 MPG.
I have a VSS, not a speedometer cable. I'm wondering if the reluctor gear on the output shaft of the transmission(700R4) needs to be changed.....I was thinking it might have something to do with the Vehicle Speed Sensor reading it wrong.
Anyone with advice please respond......
Old 11-09-2006, 03:19 PM
maxwedge maxwedge is online now
A990 racer
Re: 1990 Burb Gear Ratio Change Killed Gas Mileage
Well now the miles traveled per rpm is more so your mileage calculations are off.
Old 11-09-2006, 04:04 PM
2000CAYukon 2000CAYukon is offline
On the 700R4, you need to change the speedo gears to correct for the gear change. See http://www.700r4.com/speedoCalc/speedocalc.shtml
//2000CAYukon
Old 11-09-2006, 06:41 PM
Please understand that my gear ratio change was a 10% difference, so now when I travel 1 mile, my odometer registers 0.9 of a mile. Given that equation, my 37 gallon tank that used to give me 600 miles, should now give me 660 miles. The problem I'm having now is I can only go 500 miles on a full tank if that.
Old 11-09-2006, 06:57 PM
777stickman 777stickman is offline
Actually your calculations should be just the opposite. You geared up which means you're odo is turning less miles than before. So your 10% difference would really equate to 600-60=540. Less miles on the odo=lower mpg. Just my ....Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-09-2006, 07:09 PM
A990 racer
Correct, simple math!
Old 11-09-2006, 09:23 PM
So my mileage hasn't changed at all!!!???
