Old 11-09-2006, 02:16 PM
Toney 24 Toney 24 is offline
99 Grand Prix, Code P0480
I have a 99 Grand Prix GT with a 3800.
I am getting a P0480 code, I have replaced the temp sending unit and the relay. The fuse is good. I clear the code and it comes back, sometimes when the engine is cold.
I need help please!
Old 11-09-2006, 02:59 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 99 Grand Prix, Code P0480
Welcome to AF!!
Did you use teflon tape on the threads? If so remove the sending unit and remove the teflon tape. Use a conductive thread sealant and the problem should go away. The unit relies on the threads for ground and if the teflon tape interferes with that the unit may not work properly and set a code.
maxwedge maxwedge is offline
A990 racer
Welcome to AF. A bidirectional scanner can command the fan on and confirm the circuitry and fan itself, sounds like a wiring or continuity problem, look at the harnesses carefully.
Old 11-09-2006, 04:00 PM
Originally Posted by GTP Dad
Welcome to AF!!
The sender has 2 wires, one of those goes to a ground on the PCM.
Old 11-09-2006, 04:06 PM
I crossed pins 30 and 85 on the relay and the fan came on, this tells me that the circuit is good. Sometimes the Service Engine Light comes on even when the engine is cold. I think the problem is in the PCM, what do you think?
Old 11-09-2006, 07:07 PM
A990 racer
Check this link, but again a bi directional scanner will eliminate guess work. http://service.gm.com/gmspo/mode6/pd...CGHWE.pdfguess
