Old 11-09-2006, 10:08 AM
Morpheus_P Morpheus_P is offline
Send a message via MSN to Morpheus_P Send a message via Yahoo to Morpheus_P
Exclamation Don't lower your Intrigue
It has come to my sad attention that after lowering my "02" 3.5 Intrigue and going against geometry and engineering laws the vehicle has more issues. One in particular is my passenger side CV axle. It went out twice and is due to the way it is tweaked in the tranny side inner casing. Grease is coming out as I drive and vibrations are noticable at all speeds. Does anyone know of any aftermarket CV axles I can install to alleviate this issue? Ideas please. .
THX
Old 11-10-2006, 07:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Don't lower your Intrigue
Out of curiosity how much did you lower it? What lowering kit was used? How does alignment check out?
I know ZZPPerformance has improved passenger side half shafts for certain GM "W" body cars but I'm not sure of they are the same for an Intrigue. ZZP installed improved CV accordian covers and clamps.
Timeslip 08/12/06
AF Community Guidelines
Old 11-10-2006, 08:33 AM
I lowered my Intrigue using Eibach Gen II springs Pro Kit mated with KYB GR2 struts. The alignment checked out ok using the supplied camber kit. No issues there. The only issue I have is the passenger side CV axle. It is just tweaked in a uncomfortable position and is just a matter of time before all the grease leaks out. By the way the boot never breaks, however there is 1/8'' gap at the 7 "o" clock position from the tweak which is where the grease copmes out as I accelerate.
Old 11-10-2006, 12:48 PM
BNaylor's Avatar
Is your axle shaft stock or a reman. aftermarket? Hard to believe lowering approx 1.5" would put that much difference on the axle shaft geometry but I guess it does in your case. I've seen it is more of a problem on L67 GM "W" body cars.
You might check with ZZP tech support and see if their HD axle shafts will fit. Here is the one I was referring to.
http://www.zzperformance.com/grand_p...ts1.php?id=596
Timeslip 08/12/06
Old 11-10-2006, 01:14 PM
My passenger side axle is reman from Advanced Auto Parts. I already spoke to ZZ Performance too and they were not sure this application would work for me since it has not been tested on Intrigues as of yet. I would be the guinea pig and don't really want to be in that situation. If worse comes to worse the car will have to go back to OEM height. My frustration level is growing.. Any advice is appreciated. THX
Old 11-11-2006, 12:11 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Honestly I see no reason why the ZZP kit meant for the GP etc with the regular 4T65-E transmission wouldnt work.
The suspension of the cars are identical in almost every aspect, the Intrigue is slightly shorter than the other W bodies, but I believe the frame was shorter, and the suspension components remained unchanged.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 11-11-2006, 08:51 AM
panzer dragoon panzer dragoon is offline
what is your tire profile (size) on your lowered Intrigue.
Old 11-12-2006, 12:10 AM
LittleHoov's Avatar
Well...turns out the Intrigue doesnt always use the same Drive Axle as the other W-bodies, I stand corrected.
If you search the GM Parts Direct Catalog, you can see what other years/types of cars the particular part you need can be found on and there may be an aftermarket solution.
I dont have the part # you need, because it varies by engine and gear ratio.
You can determine your gear ratio by looking at the RPO codes on your trunklid.
code FR9- Ratio, Transaxle Final Drive, 3.29
code F83- Ratio, Transaxle Final Drive, 3.05
Old 11-21-2006, 12:12 PM
I have 245/45 18's all the way around. You seriously think a new axle shaft from ZZP will work huh...Hmm
Old 11-21-2006, 06:50 PM
http://http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=g-Force+T%2FA+KDW+2&partnum=445YR8GFTAKDW2&vehicleSe arch=true&fromCompare1=yes&place=0
check the outer diameters on these tires. When you switch from 16" to and 18" the overall tire diameter goes up when you look at the chart. If the overall diameter is going up your tire center is going up 1/2 of the increase.
Old 11-21-2006, 09:40 PM
check the outer diameters on these tires. When you switch from 16" to and 18" the overall tire diameter goes up when you look at the chart. If the overall diameter is going up your tire center is going up 1/2 of the increase.[/quote]
I understand it affects the entire tire diameter, but don't see how that will help me here. Others have the same exact set up as me, but don't have the issues I am having.. How do I post a pic on here so everyone can see what is up?
THX
