Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-08-2006, 10:06 PM
canuckfan31 canuckfan31 is offline
Question Removal of door panels
Hi does any know how i can remove my front door panels on the drivers and passenger side to get at my speakers to change the factory speakers i own a 1994 buick regal custom
Old 11-10-2006, 11:03 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Removal of door panels
It should not be that difficult. There will be fasteners like bolts around the door handle area that must be removed. The door panel is held onto the door frame with several plastic push pins clips. You can use a door panel tool or get a good grip on the bottom edges and carefully pull out. After that the door panel should lift up and out. Good idea to get replacement push pins just in case. Should be available at Advanced or Autozone.
Timeslip 08/12/06
AF Community Guidelines
