Old 11-08-2006, 07:28 PM
lynndiwagon lynndiwagon is offline
95 Blazer throttle sticking
I am buying a 4X4 1995 Blazer from my son. He just called me from the side of the road and reported that the engine was heavily accelerating down the interstate and he couldn't pull over because he was on an on-ramp. He finally turned off the ignition and got to the side of the interstate. He started it back up....all ok. He then accelerated and it happened again. He finally got off the interstate and stopped at a gas station. I had him open the hood and operate the throttle, manually. No problem. It was smooth and no hangups. He had it towed to a repair facility and they could not replicate the problem. They told him that the cruise control COULD possibly cause the acceleration. I find this hard to believe but he says that they said that they had found some service bulletins that said it was possible.. What do you guys think??? and thanks for the input. They supposedly checked all of the usual, carbon in throttle body, worn throttle shaft, etc. Sorry for the long post.
Lynn Wagoner
Old 11-08-2006, 08:53 PM
herkyhawki herkyhawki is offline
Re: 95 Blazer throttle sticking
Check carpet and floor mats carefully as they can make the pedal stick down, and then when moved later the problem disappears. There is also a plastic clamp on the cable above tha pedal that can be a problem if not seated correctly.
Old 11-09-2006, 09:01 PM
OK, thanks for the reply.
Old 11-10-2006, 11:16 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Sounds like the floormats to me.
And watch out for massive vacuum leaks. Check all hoses going to the plenum, even the ones in the back.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-24-2006, 09:42 AM
Update.....Son told me today that the Blazer was actually accellerating, not stuck. So, I guess it could in fact be the cruise control....that's the only thing I can think of that would accellerate the vehicle?
Old 11-24-2006, 10:03 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
either the cruise was on and he kept hitting resume, the throttle butterfly is dirty and sticking, or the floormats are too thick and catching the pedal.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 11-24-2006, 10:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Is it gaining speed or just holding steady?
To rule out cruise disable it or pull pull fuse.
Any check engine lights or codes.
As said TBI sticking, gas pedal ,or floor mat, and gas linkage cable itself sticking.
They would hold steady speed .
Also if the IAC valve is coming open it can raise the engine rpm.
MT
Old 11-24-2006, 04:07 PM
BlazerLT's Avatar
AF -Advisor
Vacuum leak will have it accelerating as well.
All the throttle plate essentially does is open up a big big vacuum leak.
Check ALL hoses around the upper plenum especially the brake booster.
