Old 11-08-2006, 06:59 PM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
Engine oil stop leak?
Has anyone had any luck with this stuff? If so, what brand have you used?
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear
Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement.
Old 11-08-2006, 08:17 PM
rhandwor rhandwor is offline
Re: Engine oil stop leak?
I have used it and it only works for the old type seals not neoprene seals.
I forgot the brand I used.
Old 11-08-2006, 09:02 PM
What type of seals are in an 89 5.7L
Old 11-08-2006, 09:09 PM
Unless you changed them I'm sure the neoprene seals. You can always try it but I think a full day and front and rear main seals is the way to go.
Old 11-08-2006, 09:17 PM
2000CAYukon 2000CAYukon is offline
Which seal is leaking? On my 90, I thought the rear main was leaking but it turned out to be the oil filter adapter O-ring and gasket. Much easier job than a rear main and no more leaks.
The only hassle is the oil cooling lines have to be removed at the oil filter adapter and it is a messy job.
Fel-pro makes a gasket set that has everything you need and I think it cost me around $11 for the gasket set.
//2000CAYukon
I was hoping for a temp. fix just to get me through school. I was planing on stroking it to a 383 anyway i guess.
Old 11-08-2006, 09:21 PM
//2000CAYukon
Im not 100% sure its the rear main. I didnt think it was the oil filter adapter just because it was dripping in the middle not off to the side. I guess it could be running down something to the middle though.
Old 11-09-2006, 12:34 AM
In my case, the oil was dripping from the TC cover shield on the tranny. The oil was going down the lip of the pan and dripping on to the TC cover. I thought for sure is was the rear main until I took a good look and even then I was not 100% sure.
//2000CAYukon
