Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-08-2006, 06:04 PM
abjc_77TA abjc_77TA is offline
Knock in the '77
Ok so I have a knock in my 77 Trans Am - 400 4-barrell, and there is an knock internally. I know that a common problem with the 400 is the main bearings have a tendency to go bad, but before I pull the block and rip at all apart, any suggestions about what else it could be?
NOTE: If I replace the mains, I'm going to replace the crank and all of the other crank kit parts, not just the mains.
THE PROJECT: '77 Trans Am - 6.6L Pontiac V8
Old 11-08-2006, 06:53 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Knock in the '77
sweet car! welcome to af.. i dont know much (anything) about the 2nd gens..but theres a bunch of people who pretty much tore it down and built it back up..hope they catch this one.. good luck!
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 11-08-2006, 11:15 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Welcome.
How many miles are on it?
How bad is it knocking?
ive seen many things other than mains causing a knock.Check the balancer and pully first. Then listen back at the flywheel and torque converter, as these can disguise themselvs as a internal engine noise. Of course you will need to put it up on a lift to do this very well. If you cant find the culprit, it very well could be the bottom end of the block. It also could be a piston wrist pin. If you go to all the trouble of replacing the bottom end, it would probably be a good idea to replace the pistons as well. Good luck and again, welcome to the forum.
Old 11-09-2006, 09:55 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Hotrod's got a alot of good ideas. My input is to pull the oil filter and drain the contents through a paper towel for any signs of metal debris.
Old 11-15-2006, 09:40 PM
There are 135,000 miles on it. The knock is not that bad, noticeable, but not bad. I didn't think to check the flywheel/converter. I'll have to listen for that. Thanks!
Also, I have a hardtop. Does anyone know of any company who can install t-tops? I know that i'll have to reenforce the roof to keep from blowing the back window out, but I have yet to find a company in MI that does them. Any ideas?
Old 11-15-2006, 09:52 PM
Its a long shot, but its best to explore every option before going through a total rebuild.
If you had a parts car that would make it easier. A LOT easier. Doing the work yourself can save a bunch of cash IF you can use a welder and grinder. Its easier to put a top on a car than it is to build a block.
All you have to do is come up with a welder, a grinder, reciprocating saw and a sharpie. If your good you can make your cuts, weld your welds, and not have to paint anything major. Oh yeah a tool to cut the glass out too.. or a set of guitar strings.
Old 11-15-2006, 09:53 PM
