Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-08-2006, 05:45 PM
ricnor ricnor is offline
Control Arm Bushings
My 1997 K2500 454 4x4 Suburban has cast front control arms, is it possible to get new bushes for these and is it a job a reasonably adept diy mechanic can do at home or does it need special equipment? If they are replaceable what type would be best? Also any links to good parts stores that will ship to the United Kingdom would be very helpful.
Thank you in advance for any help.
Old 11-08-2006, 06:13 PM
maxwedge maxwedge is offline
A990 racer
Re: Control Arm Bushings
GM has bushings for these at about 16.00 each, you will need special tools to install them. Also check Napaonline.com.
Old 11-18-2006, 04:33 PM
Thanks for that. Is the special tool for installing the bushes into the arms or for removing and refitting the arm's themselves. I have a press that I have used in the past for installing bushes on other vehicles.
Old 11-18-2006, 06:48 PM
A990 racer
There is a universal tool set for the job, I paid 160.00 for one and it has done old Fords as well as modern upper and lower arm bushings, got it from Napa, Carquest has it also.
Old 11-19-2006, 07:57 PM
rhandwor rhandwor is offline
If you have a 20 ton press you can install the bushings. You will then need a spring compressor to remove the whole control arm. You might get a free loaner from Auto Zone but I'm not certain exactly what they have. You will also need to remove the ball joint.
Old 11-20-2006, 03:27 PM
A990 racer
Question Re: Control Arm Bushings
Why does the ball joint have to come out of the arm to replace the bushings, never had to do that?
Old 11-20-2006, 04:07 PM
You are using a tool which he doesn't have. To take the control arm to a press in the shop it has to be completely out of the vehicle. I have a tool but if I wanted to use my press it is in another room in my garage.
