Old 11-08-2006, 03:03 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
power lock problem
ok here is the problem..when i push the button for lock/unlock..the driver side door does not work in any way..but it does lock the passenger door and unlock it..however..if i manually move the lock it will still power the passenger one to move with it..what the heck is the problem..it is not a fuse and everything is plugged in correctly..is it the motor for the locks or the actuator..w.e it is..where can i get the parts for it??? any help i would very much appreciate..thanks
Old 11-08-2006, 03:56 PM
AutostradaVR4 AutostradaVR4 is offline
Re: power lock problem
sounds like maybe a problem with ETACS or w/e its called.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-08-2006, 03:58 PM
ETACS??? what is that?
Old 11-08-2006, 06:59 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ETACS
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-08-2006, 08:54 PM
no that doesnt sound like the problem..any other ideas
