Old 09-12-2002, 08:44 AM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
F22 engine efficiency
What is the volumetric efficiency for an F22B1?
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 09-12-2002, 08:54 AM
rx racer's Avatar
rx racer rx racer is offline
figure 145 HP / 2.2L = 20.45 HP/L
1993 rx7
1994 Civic Ex
Old 09-12-2002, 09:00 AM
wrong VE
I believe engine volumetric efficiency (VE) is usually in percents. VE changes with engine RPM, a engine at wide open throttle at 3000rpm could have a VE of 90% and at 6000 rpm 60%. This is a rough guide. At maximum RPM modified engines may have a better VE, e.g.: average overhead valve engines 45% to 75%, overhead cam twin valve 65% to 80%, four valves per cylinder 75% to 90%.
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 09-12-2002, 09:03 AM
rx racer's Avatar
sorry thought you were reffering to the HP/L sometimes reffered to a volumetric efficiency (dunno if thats wrong or not)
1993 rx7
1994 Civic Ex
Old 09-12-2002, 09:05 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
At peak torque, VE% is often close to (or greater than) 100%.
To get a rough estimate of VE% at peak power, calculate the torque at peak power and divide by peak torque.
If you'd like me to do this as an example, please provide the following:
Peak torque output of engine
Peak power output of engine
RPM at which peak power occurs
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 09-12-2002, 09:07 AM
145HP/147ft-lb @5500RPM
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 09-12-2002, 09:14 AM
Made a mistake
145HP@5500RPM
147ft-ib@4500RPM
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 09-12-2002, 09:32 AM
Okay... We'll assume that at peak torque, %VE is exactly 100% (in reality it may be slightly higher and it may be slightly lower).
145HP @ 5500RPM gives us about 138 ft*lbf (145 * 5252 / 5500 =~138)
Now we'll assume that the torque drop at higher rpm is due to poor breathing (lower VE):
138 ft*lbf / 147 ft*lbf =~ 0.94 = 94% VE
So that engine configuration has a V.E. of about 94% at WOT at 5500rpm.
Old 09-12-2002, 09:37 AM
Thanks for the example. So if I had the dyno chart for my Accord, I could calculate the VE at each RPM interval, correct?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 09-12-2002, 09:53 AM
you could probably come up with some pretty good estimates.
How can forced induction increase engine efficiency? caffeineaholic Engineering/ Technical 4 07-17-2010 01:41 AM
Fuel Efficients Engines rednuslura Automotive Articles 0 06-30-2010 12:54 PM
f22 engine parts for sale 95vtecpower Accord/TSX/Accord Hybrid 0 05-03-2005 06:52 PM
F22 engine parts for sale 95vtecpower Classifieds 0 05-03-2005 06:52 PM
Any hope for a F22 engine? Hondafan96 Engineering/ Technical 4 07-11-2003 10:47 PM
