Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-08-2006, 01:50 PM
usamarshal usamarshal is offline
Coolant Leak...
Just had a pressure test completed on my truck for any leaks that I might not know about. Turns out everything checked out ok, but just in case I still lose any coolant can a dye turn up anything? The reason I ask is that I may have an intake gasket leak that I might not know about. Thanks for any info, Andrew
Old 11-08-2006, 04:08 PM
2000CAYukon 2000CAYukon is offline
Re: Coolant Leak...
The dye can only help if the leak is external. If the leak is internal, it wont help.
You best bet to watch the level in the overflow tank. If you have to keep adding, then you have a leak.
//2000CAYukon
