Old 11-08-2006, 10:04 AM
mybigredford mybigredford is offline
92 blazer s10 help please
i have a 92 blazer s10 with the 4.3 vortec engine, its been over heating bad, the temp gauge jumps up, but when i drove slow and steady it went down till i accelereated more, now it heats up after a couple miles in town. im getting ready to try and change the thermostat but heard it could be as easy as the radiator cap? can anyone help me please? thanks
Old 11-08-2006, 07:46 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 92 blazer s10 help please
Change the thermostat.
If you hear a gurgling sound behind the glovebox or the radiator hoses don't get tight with pressure, change the radiator cap.
Old 11-09-2006, 08:43 AM
i changed the thermostat, still overheats. i will change the rad. cap today .
Old 11-12-2006, 09:18 AM
Talking Re: 92 blazer s10 help please
cant believe it, i bought a stant rad. cap like suggested put it on and sure s#$t it works, thanks for the help.
Old 11-12-2006, 12:03 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
factory caps are notorious for being defective so good move.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 11-12-2006, 12:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Make sure you top up the cooling system and fill the overflow tank up to just below the overflow tube.
Then allow it to burp the excess out and settle and you will have the perfect level.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-13-2006, 06:32 AM
yup got it covered am noticing a small leak somewhere, antifreeze collecting at the bottom the the radiator by fan shrowd, could be from when i flushed the lines though. its running great hasnt even come close to overheating, one thing when i flushed the lines i noticed this grey mirky color with the antifreeze i thought maybe someone put it some stop leak before i dont know. but its running.
Old 11-14-2006, 08:49 AM
does anyone know what the grey mirky stuff could be? or what to do, will it effect stuff badly, not to worry ? anything? please let me know. thanks
Old 11-14-2006, 03:42 PM
BlazerLT's Avatar
AF -Advisor
Could be the coolant being too old and breaking down.
Maybe flush it again at the end of the winter just to be safe.
Old 11-20-2006, 07:25 AM
kick down cable loose, went to push in that silver button to adjust it, felt the cable still loose slides in and out, what wrong ? any ideas
