Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-08-2006, 05:16 AM
87BoxClassic's Avatar
87BoxClassic 87BoxClassic is offline
trunk key hole cover
is there anyway to fix the trunk key hole cover thing?, i have the part i went to a junkyard and they said they are near impossible to fix.(in my head i was like yeah rite, well he reached down and showed me a box of about 50 of them), so is it possible to fix i think it's just a spring but when i bought my 87 box it was glued on
Old 11-08-2006, 11:18 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: trunk key hole cover
What exactly is broken on it? Is the emblem part of it broken off?
Old 11-08-2006, 06:24 PM
yeah that emblem in your sig broke off the part where the trunk key hole is
Old 11-08-2006, 11:04 PM
PeteA216's Avatar
My thought would be to take off the entire unit (this may require you to drill out rivets that hold it on unless it was replaced at one point and its bolted on) Once you have it off, where the pivon point used to be, drill a hole all the way through. Then on the same place on the "door" part of the emblem droll a hold, but not all the way through. Add threads to the hole in the door part, and put a matching machine screw through the first hole and threat it into the back of the emblem. Make it tight enough where it sits nice, but loose enough that the latch can open. Use locktite to hold the screw in place if nessesary. Then get some bolts with lock washers and bolt that sucker back on using the same holes the rivets used.
