Old 11-07-2006, 11:06 PM
bigluelok bigluelok is offline
Lightbulb i need help please anyone
well my 1988 civic hatch cuts of wen i het the breaks does any one know wut that could be and how hard is it to check out the problem or problems
Old 11-08-2006, 12:46 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: i need help please anyone
Disconnect the hose to the brake booster and see if it dies. If it doesn't die with the hose disconnected, replace your brake booster.
Old 11-08-2006, 01:13 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Well if you just disconnect it then the engine will likely die anyway..You have to plug the hose with something, like your finger :P
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 11-08-2006, 03:17 AM
viper-blue's Avatar
viper-blue viper-blue is offline
disconnecting that hose will send the engine into high-idle mode. I doubt that advice will help
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 11-09-2006, 09:07 AM
skotman's Avatar
skotman skotman is offline
does it, by chance, throw a code when it kills?
just a thought.
Old 11-09-2006, 04:56 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
do you hear a vacuum noise when you push on the brake pedal?
If you do, you need to replace the brake booster. (If it's a pronounced noise)
Old 11-10-2006, 12:43 AM
how do u know when theres a code or how to check
Old 11-10-2006, 12:54 AM
viper-blue's Avatar
the code comes from the computer. Look under the dashboard on the passenger side. peel the carpet back from the floor right under the dashboard. You should be able to see a metal plate looking thing with a glass "eye" in the middle of it. When you turn the ignition switch to the on position the glass eye will blink a red light if the computer is working right. When the engine cuts out on you immediately turn the ignition off, peel the carpet back and look for the "eye". Turn the ignition on, then look for a single blink from the "eye"...if the computer has stored any codes more blinks will follow the initial single blink. if more blinks follow count them....the single blink starts the codes any more blinks will represent a code...eg. blink, blink =2....blink, blink, blink =3.....10 blinks =10...once you get the codes read the sticky on the main page that says "if you are new, please read before posting it will tell you what problems the codes you have represent.
Old 11-10-2006, 11:03 AM
i cant seem to find the sticky that your talkin about can u tell me how to get there
Old 11-10-2006, 04:27 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
http://www.automotiveforums.com/vbul...d.php?t=118785 its this one the one every one should read before askin obvious questions ect.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 11-10-2006, 11:00 PM
Disconnect and plug the hose to the brake booster and see if it dies. If it doesn't die with the hose disconnected and plugged, replace your brake booster.
Old 11-10-2006, 11:03 PM
4twenty's Avatar
4twenty 4twenty is offline
would the brake booster be responsible for the break pedal sinking down alot before the car starts actually slowing down?? because i already replaced my master and it didn't really help much...
Old 11-11-2006, 11:29 AM
viper-blue's Avatar
yes, the booster would be your next choice..my car has 289,000 kms on it....my booster has been slowly going the last 50k or so....aside from the tests mentioned here, your manual should give you some tests you can perform to or use this one:
http://www.crxpower.net/~silverkorn/...hop_Manual.pdf
gotta give props to Turtlecrxsi for the manual
