Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 11-07-2006, 08:44 PM
norurb norurb is offline
overheating problem on '95 200sx 1.6
Not sure if it's the water pump or radiator. I changed out the thermostat and radiator cap. I flushed the system and bled it by unplugging the bleeder valve near the thermostat. One radiator hose is hot while the other stays cold. My heater does blow hot air, the temp gauge does not go all the way hot. What do you guys think? Water pump or radiator? Thanks.
Old 11-08-2006, 08:43 PM
Re: overheating problem on '95 200sx 1.6
Anybody?
Old 11-12-2006, 12:27 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
the top hose is hot and the bottom cold?
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 11-13-2006, 01:09 PM
Yes, I think either the radiator is bad or the water pump is bad. But which one is it?
Old 11-13-2006, 06:21 PM
slideways...'s Avatar
slideways... slideways... is offline
does your fan turn on?
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 11-16-2006, 01:05 AM
It does not. I think it is because the hot coolant water is not reaching the "coolant temp sensor", or whatever it is called.
Old 11-16-2006, 07:29 AM
or the sensor is bad...that happens.
Old 11-20-2006, 05:22 PM
dreww dreww is offline
if the top hose isn't getting hot, then the thermostat isn't opening....at least thats the first place to look. You said you replaced it though.
usually, water pumps leak before or as they are going out. Did you notice this?
