Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-07-2006, 07:58 PM
hazafarm hazafarm is offline
2000 dodge ram heater coil replacement help
looking for some help on how to remove and replace heater coil
2000 ram.also do you need to drain ac fluid????
Old 11-08-2006, 01:41 AM
moto503 moto503 is offline
Re: 2000 dodge ram heater coil replacement help
all i have say about replacement of a ram heater coil is a bitch !!! take ur time and remove the hole dash
Old 11-08-2006, 12:22 PM
edbrycem edbrycem is offline
If you mean heater core, this is an old thread from someone but should work:I've done a dozen or so of these. First thing, don't let it intimidate you, it's not that hard. Dodge dealer wanted to charge me $700 to replace the core, the core was $250, so it is worth doing it yourself. It takes me @ 30 min to do it but it you havent done it before, @1.5 hr. First, remove panel under steering colum, disconnect wire to gear indicator{if auto} you will need to shift to low for dash clearance.Remove plastic kick panels on both sides.You will see 1 nut on each side, loosen until the bracket lip clears. Back to steering colum, remove cross bar, then drop steering colum. It will lay on seat. You can remove plastic trim on dash, it just pops off, do this so you don't scratch it. Remove all bolts in dash up near the windshield. IF you want to totally remove the dash, there is alot more, but it is not required to change core, you can just pivot the passenger side onto the seat and you have plenty of room. Once the dash is out of the way you need to go under the hood. disconect heater hoses. Now you must remove the computer from the firewall{a bolt that hodls the heater assembly is under it} DO NOT DISCONNECT THE WIRING HARNESS If you do it resets the computer(expensive) Now you will see the core in the heater assbl. when you pull back the dash but it slides straight down into the housing so you must unbolt the assembly to pull it back to get enough clearance for the inlet tubes. Replace it and reverse the proccess. I know it sounds like a lot, but once you tear into it you will realize that it's pretty simple. Pretty much everything in the dashes of this body style are easy access. Good luck.
